anybody know where to get the silicone upgrade hose that connects throttle housing to big air intake pipe? its the round large diameter hose that also has the ISV connected to it.
where to get inlet hose?
Tags: None
Hmm, confused now, I thought this was the throttle body hose which connects to the pressure pipe and to the ISV , they have a history of splitting underneath the TB , you should be able to get a OEM replacement though from an Audi dealer and I thought Vagparts, you got a pic to confirm what part your needing ?Comment
re
its the BIG hose that is 3 inch wide. connects to the huge boost pipe on top of rocker cover. its almost a T-piece,with the small pipe coming out of the top connecting to ISV but one end (next to throttle butterfly) is bigger than the other end.
Big and round.Comment
if you can speak german there is the metal pipe with the pipe that connects to the tb on ebay.de for 1 euronever set your expectations to high that way you are never disapointedComment
http://cgi.ebay.de/AUDI-S2-3B-Druckr...QQcmdZViewItem
the link to it.never set your expectations to high that way you are never disapointedComment
re
Doh! top effort matey boy but they dont deliver worldwide! FFS!
I only want the rubber part, surely someones got one kickin about after an upgrade?Comment
They are cheap enough from the dealer! Dead easy to get hold of if you just want a std part.sigpic
Tom C - www.rcmr.co.uk
Audi UR Quattro
Audi 100 C3 2.0 5 cyl 115ps
Audi B5 RS4 645ps 911nmComment
i need to learn german there is always stuff going cheap there was some rs2 front calipers going for 100 eyros yesterdaynever set your expectations to high that way you are never disapointedComment
