Boost gauge - Am I Daft
    • 12431
    got the VDO boost gauge from the group buy and some boost hose with 4mm ID and 6mm OD but I can't get it secured into the gauge.
    Am i going mad or is there something im missing? Ive attached a pic of how I reckon it should fit together but when I do the pipe lifts straight out.
    I have put the brass insert into the black pipe.
  • BrianSmith_S2
    • Jun 2005
    • 1342
    • Home: Northern Ireland Current: British Antarctic Territory
    Looks like a 'nut' and 'olive' type arrangement to me.
    The olive hoop fits over the hose, and is clamped tight around the hose when the nut is screwed onto the guage.
    Brian
    • MattS2
      • Apr 2006
      • 657
      Make sure you tighten it fully, you have to compress the olive onto the pipe.
      It's a one shot deal though.
      Matt.
      Ex owner of a 1993 Silver Avant - RS2 spec.
      2002 A8 sport 2.8 quattro Sold
      2003 A6 Avant Tdi
      Mk Indy 2.0 pinto circa 160 Bhp
      2004 VW Caddy SDi
      2002 Civic Type R
      • pastures16
        • 2058
        you say you have put put the insert into the pipe it dont look that way from the pic
        94 s2 avant
        aoc member 1116
        • pastures16
          • 2058
          first off put the nut then the olive over the pipe then push in the insert into the pipe and away you go
          94 s2 avant
          aoc member 1116
            • 12431
            Matt.
            Thats what I was worried about, wanted to double check I have got the right hose before I tighten it all up and install it if I only have once chance with it
