Petrol Coming from cyl one??
  • Azman
    • 3205
    Hi guys,
    Right got to the bottom of the brown stuff coming from cyl one on the IM Twas petrol..... So had the rail off and replaced the o rings on all injectors today. Started her up and lo and behold it is still there.
    So I have ordered a full set of 5 inserts for the manifold as it is the next cheap option on the block so to speak......
    Question is -
    Could an injector leak upwards under the O ring as it doesn't seem to be coming from behind the insert????
    I am changing the inserts as a tester just to see if they are in bad shape.... Strange how it is just ont eh one cyl though and not all......
    Thoughts guys...
    Az
    Dark Grey Avant
    RS2 FARB
    Alloy Subframe Bushes
  • mcandmar
    • Apr 2004
    • 5118
    It be a crack in the injector itself letting fuel seep out under pressure?
    91CQ20v - Gone to a new home
    93UR-S4 - The Magic Carpet
    94S2Bus - The Emerald Express
    • martinjs
      • 3205
      I had this once, wrap some ptfe tape around the thread on the inserts when you change them. Sorted it for me.
      • Azman
        • 3205
        cheers guys
        Dark Grey Avant
        RS2 FARB
