My new 3" d/p back exhaust
  • S2_Dave
    • Aug 2005
    • 456
    Originally posted by Animal Mother
    Surely the area of two 2.25" pipes is around 3.9".
    Isn't that more than 3"?
    Ok, I understand that there will be turbulent action at the "Y" but under pressure a flow in a 3.9" then a 3" pipe will still be better that a flow from a 2.25" to a 3" especially if there is a cat in the way (even if it is a sports cat)!
    I think it's something to do with the drag on the exhaust wall. With 2 x 2.25in pipes you have a total area of 7.95in² compared with 1 x 3in pipe giving 7.07in², so this has the two smaller pipes ahead by 12.5%. However, there's 14.14in of wall with 2 x 2.25in pipes, compared with 9.42in of wall with 1 x 3in. I'm sure I've read somewhere that the closer to the wall, the slower the air moves, so more wall isn't a good thing and there's 50% more with two pipes (although I suppose it may conduct a bit more heat away).
    David
    '91 3B S2 Coupe
    • Knight Rider S4
      • 3541
      You gonna get your slide rule out again Jamo?
      Rubbish I'm afraid.......
      P.S you asked for that
      93 S2 Avant Parting
      91 URQ RR
      02 A4 tdi Avant
      • S2_Dave
        • Aug 2005
        • 456
        I think two 2.25in pipes is the equivalent area of one 3.182in pipe.
        David
        '91 3B S2 Coupe
        • Animal Mother
          • Jul 2007
          • 1135
          Bingo was his name'o!
          UrS6 - Homefry, Bailey DV, PiperX filter, Samco hoses, H&R springs, 3" D/P back zorst, 270bhp and 260ftlb :rock:
          Triumph Daytona 955i - mmmmmm :fire:
          80 dag dag :driving:
          • Animal Mother
            • Jul 2007
            • 1135
            Deserved!
            • DJones
              • Jun 2005
              • 2020
              I was always told that the best systems are those that stay the same diameter front to back, (with the exception of leaving the turbo) OK you have to have bends but do not change diameter.
              I wanted to have twin out of the rear box but they did not recommend that either..
              Made my own in the end but still followed there advice...
              • DJones
                • Jun 2005
                • 2020
                Another..
                • DJones
                  • Jun 2005
                  • 2020
                  Another...
                  • DJones
                    • Jun 2005
                    • 2020
                    Another....
                    • S-Express
                      • Nov 2006
                      • 1133
                      #25
                      Amazing quality and attention to detail
                      You did that yourself?
                      • DJones
                        • Jun 2005
                        • 2020
                        I did... got the burns to prove it too.... This is the other end..
                        • S-Express
                          • Nov 2006
                          • 1133
                          #27
                          Permission to use the phrase "Top Bollock" !!!
                          I'm more than a little interested as I am thinking of fabbing up a new manifold and side exit systems for my kit car - did you hire a mandrel bender? did you have to TIG it?
                          (I have welded 0.9mm stainless sheet with stainless rods on an arc welder with good results so may stick with the simple way!)
                          • DJones
                            • Jun 2005
                            • 2020
                            Cheers, I got all the parts from Jetex, bends tube joints etc (web site is pretty clear) All the welds were done with a MIG welder using stainless wire with argon gas with the exception of the tail pipe i used a TIG on that but by my own admission I'm not good with a TIG welder....
                              No because 2x2.5 will have more back pressure than a single 3" y
                              Your thinking of total cross sectional area which isn't the primary concern as your dealing with a gas. Flow is the concern.
                              The biggest cause of restriction is at the front of the exhaust section i.e downpipe and then centre section, by the time it's hit the rear the gas has lost heat.
                              It is why on the Coupe you can have 3" downpipe and centre and then have 2.75 over the rear without affecting performance.
                              Think of it like a car journey.
                              It's quicker going on a motorway for 70mph (3") from the moment you leave your house
                              than travelling along an A road at 40mpph (2.5") before you can get to the motorway.
                              • Animal Mother
                                • Jul 2007
                                • 1135
                                I'll see how good mine is on the 24th on the Dyno as exhaust design theory is sketchy at best.
                                At the end of the day its all a bit academic with an OE manifold.
