Originally posted by Jeffer
View Post
Oil Breather System - Upgrade ? Help Please !
This is a sticky topic.
Originally posted by terrybullwon View Post7
I started on mine today...
Info on the PL6 seal here:
http://www.race-tec.com/downloads/PDS002_issD.pdfLast edited by Mark Halligan; 20 January 2008, 20:24.Mark - Modded
Originally posted by Mark Halligan View Post
If Jeffer and James still want one (I'll take two) and now markrs2. That makes 5 with another five needed, as they are only produced in batches of ten.
As described above these are motorsport rear crank seals that will not lift under the negative crankcase pressure you'll get when using a dry sump, vacuum pump or a similar set up to mine. They are not cheap at 87 quid + vat each.
If anyone else is interested let me know and I'll start another thread in the Group Buy section and contact race-tec and try to set it all up.
Five more needed....
CheersMark - Modded
