Downpipe EGT hole thread
  • Doug_RS2
    • 3847
    What is the diameter and thread pitch of the blanking plug that the EGT probes get connected to?
    I am building my own EGT monitor and just need to make sure I am getting the correct adapters.
    Following this brilliant link:
    It looks real neat.
    I think it will come in at £80 max.
    I am also going to have an alarm that will set off an audible alarm when the EGTs go above a temperature - I will make it so I can set that temp up on the display.
    I can't remember what the temp Mihnea started shouting at us when the EGT got too high - was it 800 or 850 degrees C?
    I was tempted to have 5 probes to measure each cylinder but I have read several places not recommending this on turbo cars in case the probe goes through the turbo (Greg!!)
  • S2 Ant
    • 3682
    Looks very nice and neat too
    Ant
    2011 Kawasaki Z1000
    • Mihnea
      • 1288
      850°C is the post-turbine temp that should not be exceeded under WOT conditions.
      If before the turbine, use 950 as a maximum...
      I can get you a display like mine (not with the box, only the display itself) backlit in blue, red, amber and green with the thermocouple (display calibrated for that particular thermocouple, max. 2% tolarance between 600 and 1100°C).
      The thermocouple comes with a stainless fitting BTW.
      www.MRCTuning.com
      info@MRCTuning.com
      Workshop Directions
      • Corey
        Banned
        • Sep 2003
        • 2793
        How much?
        Corey
        01636 822288
        • Doug_RS2
          • 3847
          I reckon this would cost me £18 for probe, £10 for compression fitting, £5 for the adapter to make it fit, £45 for the display and all the electronics can be had free.
          But if you can get it for a good price Mihnea, it would save me time - how much?
          • SteveH
            • 4460
            Doug, Thanks for the link to the EGT info
            I'm definitely going to build one of these. Have you looked for a supplier of the IC? I'd think Maplins or RS would be able to get these. I'll have a look on their sites today.
            91 Modded 3B
            14 A6 Avant Black Edition
            • Doug_RS2
              • 3847
              Steve,
              If you want free ICs go to the manufacturers webpage - the AD595AQ is made by Analog Devices, www.analog-devices.com Find the part and request a couple of free samples. You can do this for the voltage regulator as well - try www.national.com for regulators - these have to have a heatsink as they are dropping a big voltage across them.
              Farnell - www.farnell.co.uk does the thermocouple and compression fitting. I'm looking at the labfacility ones. 3mm 150mm long, isolated.
              I have asked for a quote for an adapter for the M12 hole in our downpipe from Think Automotive. I think I asked for a male M12 to female 1/4" BSPP steel adapter
              THe display is £59 from the US - I will have a search for a cheaper or UK source of this later tonight
              Mihnea might come back cheaper anyway.
              Doug
              • Wizard-of-OD
                • 926
                • Home: Syria Current: Canada
                Doug
                is it possible for me to just buy this gauge off the market?Or have one of the guys build one and i just buy it?
                Issam N. Abed
                iABED Industries
                iABED Email | Facebook
                The build thread
                • Doug_RS2
                  • 3847
                  I've not found anywhere you can buy this actual kit.
                  I think Mihnea has something that is very close but still waiting on prices - MIHNEA ????
                  • SteveH
                    • 4460
                    Doug,
                    I was too busy yesterday to take a look at RS and Maplins. I'll follow the links you posted
                    cheers m8
                    91 Modded 3B
                    • Mihnea
                      • 1288
                      Hey guys, sorry for the silence, been doing some late-night mapping yesterday (no, Lee wasn't in Belgium ) with a TT
                      Ok, so the full kit is 140 Euros including shipping, otherwise the probe alone is 65 Euros. The probe includes the compression gland and each display is calibrated separately to its own probe for more accuracy.
                      Keep me posted guys
                      Cheers,
                      Mihnea, off to remap an S3 soon
                      www.MRCTuning.com
                      info@MRCTuning.com
                      Workshop Directions
                      • Wizard-of-OD
                        • 926
                        hey Mihnea
                        whats up?
                        So this will take the place of the empty slot i have above my dvd deck?The probe will be from autometer?
                        Please list what will be coming in the kit,as it is i have no more room for gauges
                        Issam N. Abed
                        iABED Industries
                        The build thread
                        • Doug_RS2
                          • 3847
                          Here's the thermocouple probe, compression gland and adapter.
                          I'm going to mount the display - the red 3.5 digit KNS - in a small black box and sit it on my dash - I want in very visible, but can also remove for using elsewhere.
                          I have a couple of the AD595 thermocouple ICs and should have another couple next week if anyone wants one?
                          Just waiting on my display. I went for the one autospeed used (in red instead of amber) as it was the only one I could find with a +-20V input range - you can get a basic display for £20 but need to attenuate the output of the AD595.
                          • SteveH
                            • 4460
                            Doug,
                            I'll buy anything that's spare during your project I'm going to build something similar in the next few weeks. It's just finding the time with decorating etc. Could you PM me your number again and I'll give you a call.
                            cheers,
                            Steve
                            91 Modded 3B
                            • Wizard-of-OD
                              • 926
                              Doug when its done and i like,would you be able to offer them as a kit of some sort to the guys?
                              Issam N. Abed
                              iABED Industries
                              The build thread
