I had this link - but it isn't working for me just now - I think this lace had a very rugged looking one or it had some that were 50mm long - I'm still seacrching for the right one.
With the SS compression gland and this thermocouple it works out at £23.10 just ordered mine up so should arrive mon or tue next week.
im gonna go for the SS one since exhaust is SS too. Im planning to take the old thermocouple out this wend. The first one did break up in the exhaust, that was 1 or 1.5mm dia this is 3mm dia and should be upto the job alot better.
the sender for it is in the engine bay then a different lead to the gauge. the lead you get on the 150mm x 3mm thermocouple is huge anyway, you can buy extender leads from farnell also.
The gauge ive got is from SPA design which is a dual gauge for boost and EGT's, was about £288 from SPA Direct.
The original probe they sent wasnt upto the job though and have got the new one from farnell like ive shown on here which is from the same range as they one i was sent.
Greg,
SS in SS is not always a good idea, it is not a self lubricating metal. it can gall and pick up ( just like aluminium), be careful and use coppaslip or similar.
No it's a good question, it is a technical name for when two things rub together and cause damage to one another.
If you think of an engine shell bearing which has been damaged due to lack of lubrication, that is a form of galling.
If you have seen the damage that is causd when something had rubbed inside aluminium and the surface has 'picked up' that is Galling. It shows as grooves in the direction of movement and also small lumps and tears in the metal.
It is also used as a term for something annoying such as "the boss hasn't given me a pay rise and that really galls me"
As this jiggery-pokery on the collection of S2's owned by this forum is getting to be an awful expensive addiction.
Must stay strong... avoid the voices in the dark tempting me with thoughts about hybrid turbos, silly injectors, big MAFs, exotic manifolds, AEL blocks etc etc
