Will it flow 450-500bhp
  • xgordyx
    • Sep 2006
    • 379
    Quick question, think i know the answer but gotta ask
    Will this manifold flow 450-500
    Head over to motorgeek.com and some of them have used it up to 600 bhp on a GT35/40
    Not the ideal manifold IMO it has been removed by 034 and replaced with the Wagner RS2 evo
    • xgordyx
      • Sep 2006
      • 379
      Quite suprised it would flow as much as that, didn't think it would push much past 400.
      Ye i believe it was removed as they are prone to cracking, whitch my one has but easy fix.
      Was going to put it up for sale but might keep a hold of it now for the time being
        The thing is that manny and the RS2 manny can be pushed into high bhp figures, but they are working way past their optimum effeciency.
        There's a 2.5 stroker with that manny on running a GT30R hitting 406 wheel bhp ( approx 500 crank bhp ) as well.
        Those who visited me a few months ago saw this car in stock form, here's a "teaser" since its getting very close to completion. :wink: Eurospec Shortdeck 2.6, 8.5 compression, fully balanced Head ported with 2mm larger exhaust valves Intake manifold opened and "hogged" to eliminate the bolt...
        • GazzaG60
          • 4133
          log manfolds will flow a fair bit. those look good for 600 ish. the equivelant 16v units do a good 400whp so why not.
          the issue with a log over a tubular at those levels is heat. the flow of gas is not as clean with a log so EGT's are usually higher. spool is uslaly faster thoough.
            Easily outflows the RS2 which will do 420-450bhp.
