Nice work - what's that carbon fibre cylinder thing you've got there?
panel vs cone
that be a BMC carbon air box. im obcessed with them at the mo and putting them on all tuning jobs i do they are just so much cooler then standard cone filtersOriginally posted by dan_bNice work - what's that carbon fibre cylinder thing you've got there?
taking orders soon....
Simon.
S.P.S. TUNING
'93 ABY S2.... sold
me thinks RR URQ next :mischeif:Comment
Would be interested in one of those, give me a shout when you are sorted. How much £ are we looking at? Does it sound any louder than the original?Originally posted by sps-sithat be a BMC carbon air box. im obcessed with them at the mo and putting them on all tuning jobs i do they are just so much cooler then standard cone filters
it wern't cheap the samco elbows are quite pricy. sounds good nice woosh when you let off throttle. im sending the pipe off to a mate so he can make solid stainless ones. will let you know about cost.How much £ are we looking at? Does it sound any louder than the original?Simon.
S.P.S. TUNING
'93 ABY S2.... sold
Originally posted by sps-siit wern't cheap the samco elbows are quite pricy. sounds good nice woosh when you let off throttle. im sending the pipe off to a mate so he can make solid stainless ones. will let you know about cost.Was any progress made on these pipes?Originally posted by S2central.netWell I've got dibs on Habibs pipes - so I can do some air temp monitoring with VAGCOM on the stock air box, with the cone filter alone, and with the heatshield fitted. Then we'll have some objective info to proceed with...
I ask because i need a new cone filter and a Dahlbak style filter to MAF pipe as described above would help.
AngusLast edited by AAH!; 30 January 2005, 20:16.formally RS2 +Comment
Originally posted by s2avantCan't say for sure but the closest match they seem to do for the 3B is:
WB-361
The filter is the same as most VAG 1.6 diesel engines from the eighties and early nineties. ITG have the same part number for two different VAG filters though so it may not be a perfect fit.
ABY filter is the same as a MkII golf Gti etc. ITG part no. WB-481
Ben
oooo a ITG part number!!!! WB-481.. would this be the 80mm fitting and HUGE!!! ?
I already have a small one i want to replace with a big-en (no funny comments plz)
Im deperate for a large ITG filter
ABY Coupe
sigpicComment
Erm mate why dont you just PM Doug and ask him?Originally posted by Skioooo a ITG part number!!!! WB-481.. would this be the 80mm fitting and HUGE!!! ?
Ski,Originally posted by Skioooo a ITG part number!!!! WB-481.. would this be the 80mm fitting and HUGE!!! ?
I was doing some housework (
don't tell anyone) and I found the box for my ITG cone filter. IIRC It's the same as Dougs. Part number is JC60/80 and it is an ITG Maxogen filter.
Benthe best intentions are fraught with disappointment - gil grissom
1994 ABY Avant - it's getting thereComment
Originally posted by 4WheelDrifterDoes anyone know the dimensions of a K&N Panel filter for the ABY airbox?
Internal dimensions, 295mm x 170mm and 30mm thick.
K&N filter part number 33-2768.
Thats for an ABY and an RS2 airbox.
The 3B is different.
HTH's
Jas
2001 Avus Silver B5 RS4.
1995 S2 Coupe - sold (sniff)Comment
Awesome! Thanx s2avant I owe you oneOriginally posted by s2avantSki,
Ben
ABY Coupe
sigpicComment
Cheers Jas.Originally posted by FourringsInternal dimensions, 295mm x 170mm and 30mm thick.
HTH's
Jas
I know it's different. That's why I asked.
SSComment
