Is there any difference other than design in using two 2" downpipes side by side instead of one 4" down pipe? Just thinking because of clearance issues.
Twin down pipes?
Tags: None
Area is half as pointed out and flow is completely different too. So in answer to your question, no 2 2" pipes would not give the same flow as one 4" pipe.
Two 3" pipes are close in terms of area but packaging will be a nightmare!
I seem to remember that Doug is using a DP larger than 3" in his S2 and some use 4" and then taper it to 3".Cheers'en, AndyC
1994 ABY Coupe - Projekt AlpinweissComment
Not according to Animal Mother
To be honest 3" will flow up to 600 bhp, The less change in diameter in the exhaust the better.
Single 3" from tip to tale is great.
Doug and Mark H have massive 4" exhaust systems.
