K&N Panel filter
  • AquaS2
    • 705
    K&N Panel filter
    Been offered a K&N panel filter for a 3B, would it fit straight into my ABY. Generally speaking over all would this help the car? As i know someone who had a cone K&N filter installed in a quattro, and it wasnt doing much good for the car.
    F I R E U P T H E Q U A T T R O
    1996 S2 coupe aqua green sold
    1990 MK2 Golf gti 16v oak green sold
  • Acidburn
    • 13459
    Afaik the boxes are different on the inside I know they are definately on the outside.
    • andyg plym
      • Nov 2006
      • 4646
      3b airfilter is narrower and will not fit,they are only 30 english new,personaly the panel filter aint that great,maybe slightly nicer note though
      • AquaS2
        • 705
        Alright cheers lads, that'll do, if it dont fit, it aint the one for me.
        • sheppardnias
          • Jan 2008
          • 170
          Be careful with any longlife filter such as K&N. WIthin diesel circles they are well known for foulling up air flow meters with a a coating of oil leading to warning lights, loss of power and general pita stuff. I've had cars with and without them and can't say I felt much benefit from them being there, just a slight increase in intake noise. I have one fitted on my S6 but only cause it was there when I got the car. Chances are it's coming off and going on fleabay, they make good money second hand for some reason. I'll be interested to see if I can tell the difference when I fit a standard filter.
          • Rusty
            • 18953
            Just clean the MAF periodically either with IPA or with carb cleaner! Nothing wrong with the paper filter though, the RS2 has the same paper element in the RS2 box so it can't be that bad.
            • sheppardnias
              • Jan 2008
              • 170
              That's my point... If you check applications against the K&N list you see that quite often a standard filter is used in much higher applications. If it's capable of much higher power then there is no real need to change..
              • andyg plym
                • Nov 2006
                • 4646
                the 3b panel k+n filter is the same as a mk 5 Escort gti/2000
