Thoughts on modding an IM
  • Azman
    • Sep 2005
    • 3205
    Hi guys,
    Been thinking of gettign my hands on an ABY IM and chopping the runners off, turning the top round and rewelding it back on, chopping the throttle body section off and extending it round and over the PAS pump. Thoughts please......
    Az
    Can't afford or find a wagner for the money that I have (which is very little) but may have the chance to do a swap for an ABY IM.
    Dark Grey Avant
    RS2 FARB
    Alloy Subframe Bushes
  • spink
    • 4382
    easy enough to do with a tig and a bit of knowhow.Bloke in Ireland (Niall) did it very nicely,there is a thread over on motorgeek.Will find itlater when i get back home.
    • Azman
      • Sep 2005
      • 3205
      Cheers matey. If there is enough info on there I could point my man in the right direction fo rhim to follow.
      Dark Grey Avant
      RS2 FARB
      • spink
        • 4382
        The workshop has the first bit done i.e. chopped and reversed the body of the manifold on the inlet stacks. The next stage is to rotate the plate the throttle body bolts to by 45 degrees. I've attached pics so that you can see the work to date. My question is how do you suggest we do it and...
