Screamer pipe or not
  • K7ERG
    • 1711
    Whats the opinions out there regarding having a screamer pipe or back into downpipe?
    Craig
    Audi A6 AEL 5cyl Quattro breaking.
    Audi A5 3.0tdi Quattro Stage 2
    07947385043
  • s2_southwest
    • Oct 2004
    • 823
    i got longlife to look at this, and what with the 3" downpipe they said there wasnt enough room to do anything. I begged to differ but if they didnt want to do it then that was the end of it
    Pearl white 91-S2-3B K&N cone air filter - Home made induction pipe work - 18" RS4 replica alloys - Yokohama Parada Spec 2 rubber - Colour coded body work - Bilstein/H&R suspension - s/s 3in turbo back Longlife exhaust - SFS water hoses - Samco boost hoses - RS2 FARB - RS2 eyeballs - Squeaky interior trim & 2 bar!
    • Acidburn
      • 13459
      What do you want to do with the car after you've had whatever system you go for fitted?
      If its track days, what sort of noise limit are you allowed?
      • robo
        • Aug 2004
        • 2086
        Long Life Bristol branch did mine 3'' turbo back with seperate WG pipe shouting at the floor
        sigpic_________
        Rob
        • K7ERG
          • 1711
          It will mainly be a road car with the odd track day
          07947385043
            The noise limit is pathetically low, BUT they cannot test that when the engine is loaded up and the WG opens to let the screams out.
            I love the sound of them, but they are a bit faahrty when the WG is just opening at onset of boost. One of those active exhaust flaps from ATP - controlled by boost is the right answer... The sound test is an easy pass then.
            • K7ERG
              • 1711
              If i do the track it will be Knockhill.
              Only issue is there isnt alot off room with a 3" downpipe.
              Oh as for noise i have a 3" system with one box (side exit) it loud enough to fail the tests haha!!!
              Craig
              07947385043
              • Smith_S2
                • Feb 2007
                • 634
                The noise limit at Fintray is 108db Raymor was there at the weekend see his thread
                He recorded 87db on his S2, Whats the limit for Knockhill? I think it's 110db correct me if im wrong
                cheers
                John
                • K7ERG
                  • 1711
                  no noise limit at knockhill as far as i can see.
                  07947385043
                  • Smith_S2
                    • Feb 2007
                    • 634
                    yeah looks like your right, Looks like it depends on how much you car is worth
                    Craig that intercooler is massive, my G/F folkes stay in Abernethy when ever i head into Perth i'm always on the look out for your S4..... i'll find it one day!!!
                    John
                    • Rusty
                      • 18953
                      Donington do a drive-by test and Doug has had problems with his S4 there.
                      IIRC Robo go rid of his as it was too much for daily driving.
                      One option is to route it rearwards and run a small silencer on it.
                      • GazzaG60
                        • 4133
                        i have experience 2 cars with these both subarus.
                        the open dump with the 3" over a 2.5 with open dump gave 40-60hp estimated.
                        the noise is quite bad when at low boost but evens out at higher boost levels.
                        for out and out power then maybe but for the road its a no-no now im in my 30's
                        • Mark Halligan
                          • 2001
                          I did this sometime ago, good for a laugh but too much to live with. Way too noisy, for me at least.
                          Mark - Modded
                            Mark - your sounded brilliant on full song with that fitted... I can imagine how it could drive you a bit mad though all the time. Thats why I think the control valve would be nice so you could decide when you wanna make that much noise.
                            • Keeper of The Kitten
                              • Dec 2003
                              • 2317
                              I intend to run mine out to the passenger side not the driver's side, should be easier to live with in that direction I think.
                              Martin Cutting
