I had been told that there is a way to smooth out the roughness found on the inner side of the cast iron exhaust manifolds.i cannot say that i have found much over the net,as i would be probably not be using the correct terminology.I suppose that it must be some sort of sandblasting to be able to produce a smooth area on the inner side of the pipes.
This would give the ability to a cast EM to actually act as a tubular one(or at least reach at some point it's potential) in crack avoiding mechanism.I had read that the roughness of the tubes along with the heat are the reason of the cracking of EMs along with vibration etc.SO if there was a way to smooth those edges up,wouldnt it be good?Or is it too much of a hassle?
