Throttle Body options?
  • MGaz
    • Feb 2008
    • 698
    hi, just wondering if there are any options for my TB on my typ85 CQ?
    as some of you may know, i'm running a 2.5 GTi engineering 5 Cylinder lump now, so i'm just wondering if there is a a bigger throttle body that will fit from another audi maybe?
    or are there ANY other options for getting more air in there?. lol
    C4 A6 AEL avant quattro: daily
    TYPE-85 Coupe Quattro: clicky
    2.5L GTi engineering RE2500 190hp.180lb
    Schrick 272 cam
    C A C 2.5" T304 Exhaust
    ITG filter
    Few threads on this.
    Contact Aelred or buy the enlarged one from 034 both 70mm based on the stock TB or the VW VR6 body with adapter.
    If you want larger than that then it's one from a Mustang 80mm I believe.
    Mark Halligan is running one he'd be a good source to speak to.
    • Mark Halligan
      • 2001
      I recently got rid of the 80mm Holley Mustang TB I had, as it was really a POS, the shaft was running in bushes (which leaked air) and the butterfly was a poor fit in the TB bore. I reckon I could have carved one out of wood that would have worked better....
      I bought a far better 80mm TB like THIS from this seller on the bay. Excellent piece of kit and it works well, it's adjustable, has sealed bearings, comes with a weld on mounting flange and it's easily adapted to take the TPS. Plus it's cheap too!
      HTH
      Mark - Modded
      • MGaz
        • Feb 2008
        • 698
        HTH
        you guys know i'm running CIS? would of thought my options would be a little limited.
        Schrick 272 cam
        ITG filter
          Originally posted by MGaz
          hi, just wondering if there are any options for my TB on my typ85 CQ? As some of you may know, i'm running a 2.5 GTi engineering 5 Cylinder lump now, so i'm just wondering if there is a a bigger throttle body that will fit from another audi maybe? Or are there ANY other options for getting more air in there?. lol
          I thinking WAAAAAY back, in my early VW CIS days (mid 80's), there was something called the Weber Big Throat. It was a big (don't know/remember how big) single butterfly throttle body that bolted up to the typical VW/Audi CIS intake manifold (with an adapter plate that came with it). You might be able to find one on eBay or a swap meet.
          Dave F.
          • Albert
            • 1500
            • Country: Poland
            I sent mine 65mm S2 body to Aelred, came back 70mm very nicely polished.
            AKmotorsport.net - Manufacturing Motorsport parts that do the job. | Audi S2 on Facebook | Best way of reaching me is sending email to albert@akmotorsport.net
            • Smith_S2
              • Feb 2007
              • 634
              Is there any reason you can't to this to an ABY?
              http://www.034motorsport.com/product...roducts_id=460
              TIA
              John
              • Rusty
                • 18953
                The standard NA is a sequential twin TB. You can get the larger one enlarged further, Aelred might be able to help? The Audi TBs are usually an upgrade for mk.1 Golf GTis but having though that they were also an upgrade for a mk.2 digi 8v I then found that they're the same so another option is to source an enlarged Digi mk.2 one but as it's for a Golf it'll cost you loads.
                  TIA
                  John
                  I believe thats what I said in the 2nd post This is what Aelred and 034 do.
                  As 034 are in america Aelred is a better option for people in the U.K
                  • Smith_S2
                    • Feb 2007
                    • 634
                    Has anybody done the upgrade from 65mm to 70mm? Whats was it like, did you notice an increase in throttle response?
                    cheers
                    John
                    • Rusty
                      • 18953
                      From memory you can fit a VR6 TB with an adaptor plate.
                      • MGaz
                        • Feb 2008
                        • 698
                        is there a website for that?
                        Schrick 272 cam
                        ITG filter
                        • AndyP
                          • 6049
                          • quattro
                            • Dec 2004
                            • 768
                            I get a virus threat when i open that page!
                            Probably the longet S2 project in history EVER!
                            • Acidburn
                              • 13459
                              Could just pm him direct thru this site?
