Doe's anyone know of anywhere that makes a single cat replacement pipe? What I mean is a single pipe from the turbo to the exhaust boxes. Thus removing the y-pipes.
I'm sure some european tuning firm must have come up with something, either with or without a hi-flow cat built in. Am I correct in assuming you need at least some resistance in the exhaust to give torque low down?
Ben
I asked a place to do me a single CAT replacement pipe in SS. They quoted me £150 inc VAT fitted. When I picked the car up they had done this (see pic).........
Fooking idiots. It works fine (after they re-fitted it to stop it blowing) but it isn't what I wanted. Initially they said it would be easy to do a single pipe that got rid of all the Y section but when I asked why they hadn't done it they couldn't give me a reason other than 'it does the same job' :mad:
Anyway it must be possible to do. Go to a decent place and tell them exactly what you want.
You could go for a Milltek www.milltek.co.uk sports CAT with is a turbo back system in a single pipe to a high flow sport CAT. Strange thing is that is goes back to 2 pipes ater the CAT only to go (almost immediately) bag to one pipe before entering the middle scilencer box
£650 + VAT available from QS.
HTH
Come to think of it doesn't Doug_RS2 have a single pipe (as part of a custom exhaut)?
