HI all, finally got the Milltek fitted yesterday and what fun!
Fortunately managed to get access to a ramp at work, even then took some time and checks on the sanity!
Hardest job was removing old system as all bolts were rusted very badly! Was a pig to remove centre section!
Anyways, the Milltek went ok pretty well BUT the centre section rear hanger will not allow me to push it onto the 2 centre pipes ehough before it makes contact with the underside of the car. The end result is that there is a slight blow at the joint. The pipes in theory could probably be inserted about another inch into the centre section.
I must admit that I did not use any assembly paste as suspect the system will need to come off if I ever need t swap the cats.
Is some form of assembly paste needed? I have emailed Milltek and asked for advice, my personal opinion is that the rear hanger bracket needs moving back about 2" to allow better fitment.
Anyone else had the similar issue? Thanks in advance for any help!
Paul
Paul
