did anyone modify there pas pump bracket to gain extra movement for the pas belt?when i say modify i mean grind the top corner off..lol
wagner inlet
just use the shorter SS Bracket what i have send to you together with a shorter Belt VX 13x1015. Maybe next Time just fire me an Email, i will be happy to help you!
andComment
sorry carsten,i wasnt pulling the manifold down...i have fitted the bracket sent and fits ok,,but there is still only a little movement of the pump..the part i am intending to remove is at the rear of the pump bracket,underneath the inlet manifold..nothing to do with the adjuster,its the main alloy bracket that needs modding as the pump only moves up and down about 4mm(not enough to get the belt on without stretcching over the pulley)
will post a piccy if its confusingComment
