Reduction pipe 85 - 79 to fit BMC - MAF
  • s2bug
    • Nov 2007
    • 484
    This is getting really frustrating as I have an and K&N options and looking for ideas or contact to get either
    a 180 degree 80 - 80 mm pipe so I can attach MAF to K&N and loop under and front up to the back of the Headlight
    or
    and even better a reducer from 85 to 80 so I can fit my BMC plus pipeowrk as above
    Spoke to Roose and they can make pipework up but need x 10 of and would be about £40.00 so if any of you lot are wanting to go this route then maybe a GB is on the...
    Ideas etc
    J
    S2 Avant ABY
    You could get solid pipe made for the same price or use drainpipe tube.
    There are quite a few posts covering this as this was a popular mod a few years ago, dahlback used to do a kit and members replicated it.
    • s2bug
      • Nov 2007
      • 484
      Wouldnt it melt, plastic etc...
      Is this a B and Q type thing?
      S2 Avant ABY
        That's what a heat shield is for , I kid you not this has been done before http://www.s2forum.com/forum/showthread.php?t=3863
          Silicone hose example, it's all there if you search
          • s2bug
            • Nov 2007
            • 484
            Just found these guys all sorted for £78.00
            180 degree alloy pipe - 76 mm
            Reducer 83 - 76
            reducer 80 - 76
            Dan @ Viper
            Very helpful guy with loads of Silicon to wet all appetites.
            Happy days
            Julius
            S2 Avant ABY
              Cool. Hope you like it! Not heard a BMC for quite some time, forgotten what they're like...
