In my search for an exhaust I have been looking into sports CATS. I've been talking to Blackthorn Autocatalysts and they can supply the following:
200 cell
Pt:Rh loading at 5:1 (apparently this is OE standard)
130mm diameter
130mm long substrate
290mm total length with two cones welded on (3" exits)
Apparently this is the same size and cell count as used on the Prodrive Subarus that run at 300bhp and upwards. Blackthorn's info claims that a 200 cell 130mm dia cat is good for up to 375 hp on a turbo engine.
Total cost for the substrate and 2 cones inc VAT is £254.
Does this sound like a good deal?
Anyone know if this CAT will be good enough to pass the MOT emissions test
If I use this I should be able to get a full 3" ss turbo back system with the CAT all fitted for about £800
Any comments or words of wisdom from anyone
200 cell
130mm diameter
