Turbine to Downpipe flange
  • Billman
    • 4129
    Hi,
    i have a question and i cant find anything to help me. I want to install the holset with the modifyied K26 turbine housing. Now the RS2 downpipe flange and plate on the downpipe is 58-60 mm. The turbine exducer is 65mm. I can machine the flange to fit but what about the gasket. Can i simply cut with a scissor the original Rs2?
    thanks
    Go Holset or Go RS4
  • jade
    • Jan 2005
    • 1811
    I think the best thing would be to buy some high quality gasket material. Use a hole saw to cut the 65mm hole and a good quality hole punch for the studs
    Regards
    RS 2 580HP
    • Billman
      • 4129
      something more plug and play? It is not easy for me to find these parts right now.
      Go Holset or Go RS4
