Sizes of other engine hoses
  • Sizes of other engine hoses
    Just wanted to check before I order vacuum hoses etc.
    Vacuum hose - 4mm internal diameter?
    Wastegate Hose - 8mm ID? Wire reinforced to stop collapse under vacumm?
    Leigh
    Er, without sounding stupid does this have a name, only i phoned SFS today and they said it is just normal hose I was under the impression it had to withstand high temperatures tho and had to be a high temp hose....
      Good question! Anyone.............
        I got the heavy duty 8mm stuff from SFS. I'll have a part number somewhere. ****
          Leigh, WG hose is pressure only but needs to be heat resistant also.
            Cheers. They SFS only list the nomex from 13mm upwards. I'm sure they'll recommend something when I call them.
            Thanks
            Leigh
              When i phoned SFS yesterday, i was told that they are only now selling/manafacturing for trade as such, and could not supply it to me.........
                WTF? I'll call them in a moment and see what they say
                  Bump
                  For S2Central and the others is this the stuff?
                  SFS WIRE REINFORCED HOSE
                  Wire-reinforced hoses offer increased flexibility, very high burst pressures, and will notcollapse under vacuum
                  SFS
                  METRIC (mm): 8.0
                  Part Number Part: WHL8.0
                  Number(Fluro-lined???): WFHL8.0
                  How much of the stuff is required to replace the existing hose? 1M be enough?
                  Also will this be the vacuum hose part numbers? 3M length
                  VACUUM TUBE
                  • Standard colours blue, red, fluorescent yellow, black
                  • Supplied in 3m lengths or 30m coils
                  • Vacuum line, washer tubing, coolant overflow, wire insulation, emission control
                  Bore x Wall(mm): 4.0 x 2.0
                  3mtr Part No: VT4-3-*
                  30mtr Part No: VT4-30-*
                  If i someone would be kind enough to confirm as i'll order some to go with the black Samco hoses and fit the lot in one go.
                    I think 1 metre is enough of the 8mm stuff - if it is just used for the WGFV.
                    You don't really need the wire reinforced stuff. I just got some for other tubing and it was VERY expensive.
                    I think 2 metres is plenty for an ABY - I think the 3B uses more vacuum hoses
                    If you want SFS hoses cheaper than you can buy direct from SFS - speak to Lee on here - he is a distributor - he has more clout than you or me phoning up and so doesn't have to wait as long to get stuff made.
                      Agree with Doug - the reinforced 8mm stuff is only needed from turbo to WG via the WGFV. You really want 4mm internal diameter for the narrow control hoses. That doesn;t need to be reinforced - unless you are routing them differently from stock.
                      You can usually blag some discount from SFS over the phone if you are ordering decent quantities, so YES - if we have a friendly distributor on the forum who can get better prices then all the better
                      paul
