Wagner Exhaust Manifold v RS2 Manifold
Who said it won't make more, as I explained umpteem times you can push anything beyond it's limits but back pressure and EGT's are at high levels with an RS2 manifold at those figures which makes for burnt valvesComment
I believe that the RS2 manifold isnt a restriction with a GT3071 .63 AR because simply the GT3071 cant make more than the manifold can support.
Appart from this and for tech reasons i believe that the only restriction beyond 450 hp on the RS2 manifold is this K26 flange and nothing more.
So, since the GT3071 with K26 or T3 flange has as 0.63AR this tiny neck and turbine impeller then you would make no more than 10hp with the wagner mani.
This applies only for the GT3071. Everything bigger would for sure benefit from the bigger runners and flange on a Wagner T3 mani.Last edited by Billman; 1 May 2009, 10:07.Go Holset or Go RS4Comment
