Question about exhaust manifolds
    In my quest for a cost effective supplier of a modular 3" stainless exhaust system - for Coupe initially - I need to know if the S2 and RS2 manifolds position the turbo in exactly the same position. I've never had two side by side on the bench to compare.
    Also - does the Wagner RS2 Evo manifold line up as per RS2 locations ?
    Reason I ask is to ensure that the downpipe is suitable for those three applications as a minimum. I guess one way to know is if the 70mm downpipe from RS2 can be bolted directly onto S2 manifold and stock turbo. Anybody BTDT ?
    I will have a flexi section incorporated at bottom of downpipe so there will of course be some room to adjust for dimensional variance.
    I'll post more info when I get it... I may have a road trip to get this sorted properly.
    Paul
  • A80Avant
    • 10873
    • Country: Greece
    all i can say for sure is that the RS2 EVO manifold is made to be an excact change from the RS2 manifold
    • s2_bo
      • Oct 2005
      • 6067
      Yeah, oem rs2 and evo line up exsactly the same.
      Cant say i have swaped all 3 including the s2 one around in a row though but i would imagine that they are all the same.
      91 S2 coupé - RIP
      98 S8 - Luxury barge
        OK - cool - I figured as much... Just needing the independent evidence you know !
        I'd hate to go to lengths for a generic downpipe then find its all wrong when upgrading from S2 manifold...
        • mcandmar
          • Apr 2004
          • 5118
          Had them side by side and didnt notice any difference. Turbo housing might have an effect on position too.
          91CQ20v - Gone to a new home
          93UR-S4 - The Magic Carpet
          94S2Bus - The Emerald Express
            Just remembered... I have an old K24 and S2 EM in the secret spare stash... And an RS2 turbo (perfect except for cracked hotside housing)... I'll do some investigation.
            • Big Lee M
              • 2571
              The RS2 downpipe bolts straight up to the S2 manifold as well did it last week. Hope this helps.
              Just some finishing touches to do now
                @Lee - was that with S2 or RS2 turbo fitted ?
                • Big Lee M
                  • 2571
                  Just the standard S2 turbo.
                    Thanks - we are getting warmer
                    • s2_bo
                      • Oct 2005
                      • 6067
                      You have an rs2 turbo in the secret stash? Thats like saying you have £500 under the floorboards in your kitchen...
                      What a waste
                      91 S2 coupé - RIP
                        I most certainly have a stash - in different places - worlds slowest project you know... Almost getting to critical mass with the major bits and the motivation to really make a start. If only I could fix the damn water leak then I'd feel good about doing the go faster thing.
                          PS - How much for a Wagner RS2 Evo EM by the way ? That is one big lump missing right now... I already have the Wagner IM in another stash. Sneaky aren't I ?
                            You'll be on one of those generic antiques shows like cash in the attic with them before they get on the coupe
                            Secret stash doesn't suprise me... you've been at this a while. I've just got bits for the track, if you want to go faster, take some brave pills beforehand!
                              Your probably right Andy... was planning it more for a 'fun' engine build project that could be roadtested and tracked awhile before selling it onwards for someone else to get better use out of - seeing as my car is somewhat dual purpose... BUT if I can work things that the Coupe becomes a proper low mileage weekend toy then the bias of sensible compromise can be swung out the door.
