This was a custom exhaust from a place called Pro Speed in Cardiff. It's 3" from the turbo back (well top of the DP anyroad) with a sports cat and then it drops to 2.5" to go over the rear axle, single box with twin 2.5" straight cut pipes. Nice and subtle till you give it WOT. You can also hear the airbox doing its growl thing when I got WOT in the drive-by vid.
Sounds great! Dont care what anyone says Audi is THE only 5pot sound worth listening too. A "remould" at work thinks his "Tango Chav Charriot" sounds like an S1! Oh please!
I use VLN media player, much better than Microsoft Media Breaker and Apple Slowtime. Just make sure you check what you're installing, it's free cos it tries to get you to install other things
Download VLC media player, the free and open source multimedia player for Windows, macOS, Linux, Android and iOS. Plays most video and audio files and streams.
nope car is up on stands (brings back memories) and going to try and disconnect at base of downpipe and slide whole exhaust assembly out (split at point where it goes over rear driveshaft) becaue the cats are held on buy knackered nuts/bolts so going to just grind them all off
Videos are off a pretty old camera, 6 years or so. They're pretty small but give an idea I guess. Will be stripping the alpinweiss out to look into sound deadening removal / replacemet. Should be nice.
