MAF is 3B the same as ABY
  • Paulm
    • Dec 2003
    • 489
    I need to try new MAF to see if it will sort out my boost prob but cant find ABY MAF, will 3B do
    I have a spare 1 of my EVO but I bet that wont do either
    Paul
    S4 2.7 Twin Turbo, with a few mods
  • dkw_dude
    • 555
    • Country: Norway
    Paul
    According to E**A 3B and ABY use the same MAF
    Cheers..
    Leif-Helge
    -91 S2 VEMS and Comp Turbo
    -12 B** 530XD Touring "S2 parts transporter, and daily driver"
    • martinjs
      • 3205
      Yeah, pretty sure they are the same, i'm using an aby maf in my 3b with no probs.
      martin
      • Paulm
        • Dec 2003
        • 489
        cheers lads
        • Mihnea
          • 1288
          A MAF has normally nothing to do with boost problems... Can you describe your boost problem???
          Cheers,
          Mihnea
          www.MRCTuning.com
          info@MRCTuning.com
          Workshop Directions
          • Paulm
            • Dec 2003
            • 489
            Same as its been since i bought it
            30mph in 4th WOT 17psi boost by 2600rpm ish, then drops back to 12psi from 3 to 4 k then 15psi.
            It feels like it wants to go. it is not missing but feels like it is holding back going a wee bit then holding again. by 4k it clears its self.
            If i thrash it 1st & 2nd 15psi all the way
            3rd & 4th 17psi all the way
            5th 21psi all the way it starts dropping again about 5k ish
            Lambda reading WOT .89 volts
            No boost leaks
            New Altitude sensor
            getting this fixed would be good
            Paul
            • Mihnea
              • 1288
              What fuel are you using??
              No boost leaks
              New Altitude sensor
              Paul
              www.MRCTuning.com
              info@MRCTuning.com
              Workshop Directions
              • Paulm
                • Dec 2003
                • 489
                always Optimax or Super
