Intake pipes theory
  • speeding-g60
    • Aug 2008
    • 1186
    on my 35R i run 2.5" from turbo compressor to intercooler and 3" from intercooler to 70mm TB.
    here is a quote from VWVortex, from Frederick. it gets kinda technical.... but its the mathematics of it....
    Originally posted by |foffa2002@home|
    Did some fast calculation myself.
    Could be incorrect due to all conversion from Lb/min to litre per min and from meter per second to mph etc.
    BWTF .... Books say do not exeed MACH 0.4
    Mach 1 is ~761Mph
    So MACH 0.4 is ~304Mph
    304Mph is ~136meter per second .
    So this is the aim to be below
    At wot/redline My turbo boost ~56Lb/min = 25.4kilos a minute
    1 kilo of air is ~ 1m3 or 35,3 cubic foot.
    So its 25.4M3 or 896.6cubic foot per minute.
    To get Mach 0.4 or 136m per second at 896cmf that could be anything from 500-590Hp depending on temp and fuel
    So 56Lb/min * something between 9-10,5 = Hp
    60mm/2,36inch INNER diameter piping will result in 148meter per second.
    This is normal thin whall stainless piping ...alu piping is often have thicker walls so its comparable to 2.75 inch outer.
    So thats not what we whant for our 500hp project.
    So what piping will keep ME under Mach 0.4 ?
    A 63mm inner diam a.k.a 2.5 inch inner diam piping will do Mach 0.4 at 56lb/min.
    So im going for 2.75 outer with ~65mm inner for HOT side
    And 3 inch for Cold side .
    No temp etc is in this calculation.
    Max Hp before it goes way to high!
    So its better to make a bigger dimater pipe with smarter shorter routing with less bends and less difference in area.
    If you use alu piping make sure its required inner diameter.
    Stailess steel is often in thin wall
    500-550hp = 3inch piping with atleast 2,75inch inner diam
    450-500hp = 2.75inch piping with atleast 2.5inch inner diam.
    400-450hp = 2,5inch piping with atleast 2,3 inch inner diam
    350-400hp = 2.25inch piping with atleast 2.1inch inner diam
    250-300hp = 2inch piping with atleast 1.8inch inner diam
    http://hemsidor.torget.se/user...ength
    http://www.turbobygarrett.com/....html
    • gnutz2
      • Aug 2006
      • 928
      @ speeding-g60
      According to that info the air in your turbo to IC pipe is exceeding 0.4 mach. You need to replace this with 3" tube.
      The ONLY S2 Golf!
      10.42@138mph
      • |Maku|
        • Apr 2005
        • 248
        • Home: Estonia
        Exactly, shouldn't you go for at least 2,75inch inner diam?
        What size is your 35R cold side outlet?
        EDIT: From what point speed must not exceed 136 m/s? Is it before intercooler, after intercooler or before intake manifold?
        • quattro84
          • Mar 2006
          • 947
          the 'mach 0.4' is already a guess, so i wouldn't take this too seriously.
          its better to make a bigger diameter pipe with smarter shorter routing with less bends and less difference in area
          that always goes
          • |Maku|
            • Apr 2005
            • 248
            • Home: Estonia
            #20
            speeding-g60, enlighten please.
            • speeding-g60
              • Aug 2008
              • 1186
              i want to say the 35R cold side outlet is 2.5" OD. and i run SS or CS piping, not aluminum. the thin wall of aluminum tubing can crush easily with good t-bolts.
              • |Maku|
                • Apr 2005
                • 248
                • Home: Estonia
                #22
                But have anybody thought of two step intake for 2.2t?
