Ehaust pipe step up sleeves
  • ChrisD
    • Aug 2005
    • 40
    • Home: England
    Sorry to come in with a question that is nothing to do with S2s, but this is such a great, and active, forum someone may be able to help.........pls!
    I am in the process of putting an RS6 exhaust onto my 4.2 A6. This is from the cat back.
    The external diameter of the pipe from the cat is 50mm and the diameter of the RS6 exhaust is 65mm. Therefore, I need a step up sleeve – 50mm to 65mm. I have tried GSF, Euro car parts, Allarts, Unipart, etc. They have all been unable to supply this size. I have also tried local exhaust dealers to no avail!
    Does anyone have any idea where I may be able to obtain this sleeve from?
    Thanks
  • s2driveruk
    • 12696
    sure a custom exhaust place will have or can make these
    1992 3b S2 Coupe
    • ChrisD
      • Aug 2005
      • 40
      • Home: England
      I am long out of touch with "blinging" cars, so do not know where I would look for a performance exhaust centre.
      I am in High Wycombe. Buks - any suggetions?
      Thanks.
      • s2driveruk
        • 12696
        not local but worth a call.....something similar
        JETEX - STEPPED SLEEVE 64/67/76 OD - J-SS-3 - Stepped sleeve with three diameters, used to join systems of different size tubes. Click on image for pipe dimensions.
        1992 3b S2 Coupe
        • A90TURBO
          • Jun 2009
          • 101
          • Home: Ireland Current: United Kingdom
          Also try here, good guys to deal with.
          look about half way down the page
