why not?
  • s2carlo
    • 252
    why not?
    I have mounted a cone-filter directly on to the MAF.
    However now it's pointing backwards and there is a large possibility of heatsoak.
    I would like to make it point forward.
    Dahlback has a beautifull 180 degree curve for it (very expensive)
    Some use a hose, easy but mostly no smooth surface giving turbulance.
    Some use piping, that's heavy.
    Why not use PVC piping? It light, smooth surface, all kinds of joints, easy to modify if needed, bad heat conductor?
    Any reasons why this is not used??
    Carlo
    No power, no glory!
    S4 Avant, 2003, K&N-filter, 18", RNS-E, enough audio
  • s2driveruk
    • 12696
    I'd be very interested in what you manage to find as mine is the same at the moment and I am not happy with the location but I haven't found a decent solution to change the location so that it looks forward ..
    David
    1992 3b S2 Coupe
    • s2carlo
      • 252
      Well, as no one seems to have an opion or experience I descided to try it.
      Untill now it work perfectly.
      I used 2 PVC 90 degree bents, diameter 75mm, and some connection material
      The pipes stay nice and cool, even after a firm drive.
      The suction- and blow-off sounds are nice.
      It is a low cost solution (25 euro excl. the filter)
      The filter I am using also has "suctionarea"on the inside. I also have tubing to bring cool air from under the bumper strait into the filter which creates a kind of ram-air intake.
      Below some pictures of the current status
      Carlo
      No power, no glory!
      • s2carlo
        • 252
        ___
        No power, no glory!
        • A6 AVANT
          • Nov 2003
          • 321
          Excellent!! looks like a few people making a trip to Travis Perkins for some black plastic drain pipe!!!
          A6 Avant Tdi 110 because as the fuel prices keep going up I am so happy to be getting 649.8 miles to a tank of diesel!! (£50)
            • 12431
            I had thought about doing something like that, wasnt sure how well it would work though.
            • Sweeper
              • 1317
              • Country: Latvia
              s2carlo: excelent work ! basicly it look's the same as dahlback item apart that your shield is better. It covers maf and MAF-Turbo house that also need heat protection.
              Once again great work.
              P.S. Guys , why I'm having "brrr brrrr brrrr" noice coming from the filter box place after instaling the same system on gear changes and clutch pedal pushing as on the picture ? Any thought ?
              Vadim.
              New engine (mechanical PKM head) , Alcon 332mm brakes , Pauter rods , Mahle pistons, GT30R , kw v2 sucpension , new exhaust. 608HP. For SALE !
              • GandalfS6
                • 332
                • Country: South Africa
                Sweeper - I wondered about the same noise with my cone filter , but I think I have figured it out. As you lift off the throttle, the DV releases boost into the MAF to Tubo hose. If there is a lot of air being released it would blow back through the filter. It is difficult for the air to blow back through a filter box but very easy with just a cone filter. With a stock filter box you would not hear the sound as much as with a cone filter. I get the idea that the cone filter almost amplifies the sound.
                1995 Silver S2 (ADU) Coupe
                2006 Porsche 997 Carrera S
                2006 Misano Red RS4
                2004 VW Touareg V8
                2007 Golf Mk1 Race Car
                2004 Mercedes Benz Vito 112CD
                • GandalfS6
                  • 332
                  PS Carlo - nice work!
                  2006 Misano Red RS4
                  2004 VW Touareg V8
                  • s2carlo
                    • 252
                    I have the same sound.
                    It occurs if no longer power is requered. It's more clear if the turbopressure has been up and then dropped by the ECU.
                    It's one of the nice things of driving with a cone filter.
                    Outside you hear a whoooeeessshhh sound . People turn their heads on it on a regular basis.
                    From what I am told Gandalf is correct on his analyses about the cause of the sound.
                    No power, no glory!
                    • DAVIDP20V
                      • Dec 2003
                      • 165
                      had a go with my car today, using the black pvc tubing, just got to make a heat shield, post pic 2mora.
                      sounds very nice
                      DAVIDP20V - 95' Polar Silver RS2 standard 315 bhp, forge diverter valve, Mark H mod and boost gauge..... and shes for sale.
                      • horvathg
                        • Dec 2003
                        • 556
                        Sweeper,
                        I had a similar noise, just to find that the dump valve was faulty. The forum suggested to swap for an S3 dv and its gone since.
                        Gabor
                        96 ABY coupe full except sunroof. With Porsche big red brakes, remapped ECU, xenon lights, RS2 MAF
                        • horvathg
                          • Dec 2003
                          • 556
                          Originally posted by horvathg
                          Sweeper,
                          And lets distinguish the wsssshhhhhh sound of the healthy DV from the brlbrlbrl of the worn out one. The difference is clear once you've heard both.
                          Gabor
                          • Billman
                            • 4129
                            Can someone post some wave files with these DV noises? Mine sounds like a Horse!!!
                            Go Holset or Go RS4
                            • Mihnea
                              • 1288
                              Great job Carlo, good to hear from you again
                              Mihnea
                              www.MRCTuning.com
                              info@MRCTuning.com
                              Workshop Directions
