Aluminum MAF housing
  • terrybullwon
    • Mar 2006
    • 8782
    I had a guy that was willing to make one, when i was up in Bath but i have moved on now and he has all my drawings and messurement.
    Has any one built one before?
    Cheers James
    Chef
  • fish
    • Aug 2007
    • 2335
    • Home: United Kingdom Current: Sweden
    www.cp-service.se has them, they are CNC lathed and milled. looks bloody nice his piece of kit.
    Audi 80 Competition -94 Daily driver
    www.garaget.org/fish for more pic´s of my cars
    • terrybullwon
      • Mar 2006
      • 8782
      Schweeet!
      Chef
      • terrybullwon
        • Mar 2006
        • 8782
        It was not this one fish?
        Chef
        • twoqu
          • Sep 2003
          • 3103
          http://cgi.ebay.de/Luftmassenmesser-...3A2%7C294%3A50
          • terrybullwon
            • Mar 2006
            • 8782
            Is that aluminum? My german is no exsitant
            Chef
            • s2_bo
              • Oct 2005
              • 6067
              THat ebay ones looks neat, doesn't say what its made from but it does say that the picture is without the welds. And he also says he can convert it if you send him yours for just 7euro.
              Also listed are other sizes.
              If i had knows this before it would have saved no end of trouble with trying to fit the oem maf in to the wagner IC to TB hose........
              Ill have to order one up anyway to change it over as im not happy with the current set up.
              Thanks for posting the link..
              91 S2 coupé - RIP
              98 S8 - Luxury barge
              • lind4hl
                • Jul 2008
                • 2465
                as you see the bores are bigger also= you will get more fuel into the engine since the readings will be incorrect if you not do an mapping
                • driftin jo
                  • Sep 2007
                  • 2222
                  Surely you would get less fuel into the engine without mapping !
                  If the bore is bigger and you use a standard hot wire sensor in it less of the air coming in is passing the wire so the reading would be low.
                  • lind4hl
                    • Jul 2008
                    • 2465
                    do´h of course
                    • terrybullwon
                      • Mar 2006
                      • 8782
                      bo can you drop him a message to see what its made from? I will try to catch you on msn cheers james
                      Chef
                      • Tommy200rs
                        • 285
                        the ebay measures (@private offering will disappear from ebay):
                        Original LMM Audi RS2 outer dimension 80mm and inner dimension 72 mm.
                        Available dimensions and relation to original size (% increase)...
                        Außen Innen als Original
                        80 mm 74 mm 6 %
                        80 mm 76 mm 11 %
                        Standardgröße 90 mm 80 mm 24 %
                        90 mm 82 mm 30 %
                        Standardgröße 90 mm 84 mm 36 %
                        Standardgröße 100 mm 90 mm 56 %
                        100 mm 94 mm 70 %
                        100 mm 95 mm 74 %
                        Strange that the seller is not offering x% bigger injectors....
                        • Ruffiano
                          • Sep 2007
                          • 1458
                          034's piece
                          • robo
                            • Aug 2004
                            • 2086
                            Admin why was my post deleted?????????????
                            I have replyed to James's post about 23:50 which was also deleted.
                            sigpic_________
                            Rob
                            • Losgard
                              • Jun 2009
                              • 41
                              May i ask why you want one in aluminium?
                              Vroom vroom
