3" exhaust question
  • 20Vcqdriver
    • 829
    Just had my custom exhaust done and after a long chat with Ian Birch of Pipewerx I went for 2 freeflow silencers and 2.5" with 3" downpipe option using mandrel bends as this setup will take 360 to 380bhp max without any serious backpressure issues and no boominess...
    If you're aiming for more than this then you'll need 3" all the way...
    1986 Coupe q - 2281cc 3B, chargecooler, 2.75" exh & downpipe, ported head, water injection, CGR box, modified MD357 turbo, 440cc injectors, high power coil.
    2004 A4 2.5TDi convertible, re-mapped to 180bhp
    2011 A5 sportback 3TDi-Backbox delete, remap
    • nip
      • Apr 2006
      • 1786
      • Home: United Kingdom Current: Abu Dhabi
      Mines 3" from turbo back, 2 small straight through boxes, a bit boomy but on wot sound good
      • MarT2
        • 175
        • Country: Spain
        The downpipe is the same from the turbo to lambda bung in RS2 and ABY?
        Because my engineer says to use the original part of the DP from the turbo to the lambda bung.
        It's a good idea o is better do it all in 3"?
        • adamw
          • Dec 2005
          • 348
          • Country: Shetland Islands
          best to get a FULL 3" because the oem rs2 DP is 2.75"
          cheeRS adam
          RS2+
          • MarT2
            • 175
            • Country: Spain
            #20
            But it's 2.75" from the turbo or from the lambda bung?
              That's just lazy downpipe building he needs a 2.5 to 3" transition
              • 93URS4Avant
                Registered User
                • Oct 2007
                • 255
                #22
                If you go ahead with the 3" exhaust system - you will be revisiting it within the coming months when the continual ringing in oyur ears - and inability to hold conversations over long journeys will become a drag - other than that - it will sound awesome!!!!!!
