yes mate,304 ss
downpipe
Standard engineering terminology, like an exhaust joint where a smaller pipe is inserted into a larger pipe or swaged section where the OD of the small pipe and ID of the large pipe are very close so can be easily sealed.
In this instance the smaller diameter OE pipe fitted inside the 3" pipe nicely with the OD and ID being very close, they were then sealed and seam welded. There's a pic in my for sale thread, 'hybrid' I think I called it.
Problem is that the OE pipe by the flange has a few quite significant dents in it for clearance so it's not that good for high power, fine for a more modest project and very cost effective too. Replacing it will yield better results but access isn't as good, not that it's great, as Charlie at Prospeed will tell you ad nauseum... you need a Steph to get the DP nuts undone easily... and to torque the crank bolt perfectly.Last edited by Rusty; 9 December 2009, 21:27.Cheers'en, AndyC
1994 ABY Coupe - Projekt AlpinweissComment
not bad,i bought 5x1m for £80 including postage.
and 45 deg bends use to be £27 now sales for only £16[SIGPIC][SIGPIC]/SIGPIC]92 3B pearl white=gone back home to Germany,probably in bits and pieces
RS2 VOLCANO BLACK] soon to be broken to bits
Standard engineering terminology, like an exhaust joint where a smaller pipe is inserted into a larger pipe or swayed section where the OD of the small pipe and ID of the large pipe are very close so can be easily sealed. In this instance the smaller diameter OE pipe fitted inside the 3" pipe nicely and th OD and ID were very close, they were then sealed and seam welded. There's a pic in my for sale thread, hybrid I think I called it. Problem is that the OE pipe by the flange has a few quite significant dents in it for clearance so it's not that good for high power, fine for a more modest project and very cost effective too.
Picture? sounds weird..
One thing i've learned we are way behind the Scandinavians!Comment
