Chattering...
  • dan_b
    • Sep 2003
    • 3670
    #31
    I can hear the turbo whistling too when it's spinning up, but yes the noise is exactly as Gandalf describes. I am getting used to it, but it still feels a bit boy-racer-ish!
    • Pete_RS2
      • 800
      #32
      I've noticed my RS2 "chatters" when lifting off/changing gear. Sounds pretty cool actually Does this mean the DV is healthy & doing it's job ? I didn't get the noise on my old S2...
      Now RS2'less
      '99 VW Passat VR5 Sport
      • audiman
        • 4827
        DV valve is leaking internally Peter, thats what happened to my old one, was causing an internal boost leak. Worth changing it, maybe for a forge one or even an S3 one would be better than stock and only 18 quid
        Tom C - www.rcmr.co.uk
        Audi UR Quattro
        Audi 100 C3 2.0 5 cyl 115ps
        Audi B5 RS4 645ps 911nm
        • Pete_RS2
          • 800
          #34
          Cheers Tom. I've just ordered an S3 one from VAG Parts. What's the benefit of the S3 one ?
          Now RS2'less
          • audiman
            • 4827
            Its cheaper and the spring inside is stiffer than a stock one. Im not sure entirely about the pros of it. I was just told by Mihnea to use it on my car. He did explain it to me, but i wasnt listening to him.
            Audi UR Quattro
            • DAVIDP20V
              • Dec 2003
              • 165
              #36
              you beat me to it tom !
              Yea that chattering, group "a" type dump valve noise is a fooked dv. although the dv looked all ok (no cracks, holes and the diapraghm was sealing !)
              My car started doing it a couple of weeks ago i have now upgraded to a Forge fmdv006 for around £90 + vat , and now it is back to the normal whoosh when i let off the throttle.
              But i still has what sounds like a boost leak under the dash @ full boost, i think the boost gauge cheap piping has split ?!?
              DAVIDP20V - 95' Polar Silver RS2 standard 315 bhp, forge diverter valve, Mark H mod and boost gauge..... and shes for sale.
              • audiman
                • 4827
                Bet thats the throttle body rubber hose split. They break right on the edge of the hose clips. Normally underneath where you cant see it. Have a look then order the samcos
                Audi UR Quattro
                • Pete_RS2
                  • 800
                  #38
                  LOL. I dumped the hard piping that came with the fitting kit & replaced it with some nice SFS silicone.
                  Now RS2'less
