Bigger Is Better?
  • david
    • Oct 2008
    • 1268
    Bigger Is Better?
    i was just wondering whether a bigger downpipe like 4"inch would be any good on s2.
    i know the normal thing to do is to go down the 3"DP route,after all the bigger the better.
    or this option is only for serious track cars?
    [SIGPIC][SIGPIC]/SIGPIC]92 3B pearl white=gone back home to Germany,probably in bits and pieces
    RS2 VOLCANO BLACK] soon to be broken to bits
    It is better yes but you pay a slight price off boost and also it's far noisier!
    Only applicable for 500 bhp plus applications
    • lind4hl
      • Jul 2008
      • 2465
      As said, less backpressure, but also more noice
      If youre planning to upgrade later and you can live with the noise, i wold consider a 4" dp and then just change/ remake the top of the DP after the new exhaust mani/ turbo.
      • david
        • Oct 2008
        • 1268
        so what your saying is,it only applicable for higher hp really.but what if i wan't to bolt one on now for future upgrade?
        at the moment i'm contemplating putting 3"DP,but if i can get away with 4"DP then why not.atleast i'll be saving myself time and money in the long run
          As said depends on your future bhp plans and if your car is a daily, 3" will support most needs
          I looked into getting 4" but it's hard to fit and also not many places will custom make them.
          • david
            • Oct 2008
            • 1268
            at the moment i've got 2.5" LONGLIFE ss with no back box,just twin outlet exhaust pipes and that's sound quite boomin enough for little pipe's.so a 4" DP sound will be something else.
            • david
              • Oct 2008
              • 1268
              well Jamo i'm teaching myself how to TIG weld at the moment
              i'm a bit useless at the mo,but giving time i just might get the hang of it.
                Speak to messers Terrybullwon, S2spike & Lind4hl
                • GazzaG60
                  • 4133
                  id excho the 3" is easier than 4. i can remove my 3" pipe in not a lot of time. id expect 4" would be tight maybe need mods down below.
                  one option is 3" plus atmosheric dump of gate
                  • goodall
                    • Jul 2008
                    • 810
                    If gas velocity drops too low in the exhaust the gas cools and gets thicker/heavier and makes extra back pressure due to higher viscosity and loss of inertia, meaning engine has push harder expel the exhaust
                    heres some numbers to help understand how much each size pipe changes cross sectional area, iv assume the sizes are the internal bore even if it isnt
                    2.5" = 19.63495"²
                    3" = 28.27433"²
                    3.5" = 38.48451"²
                    4" = 50.26548"²
                    if you assume cross sectional area is representative linearly to power output, using jamos figure that 500bhp=3" we can assume a 4"=(50/28)*500=893bhp
                    so unless your planning for that peak power and peak is your only concern, bigger isnt always better
                    • Audi_CQ
                      • 940
                      • Country: Norway
                      About backpressure: Size isn't everything
                      A 4 inch DP with a lot of "bumps", small turns and so on because of lack of space could flow less then a "clean" 3.5" DP.
                      Just my $0.02
                      • terrybullwon
                        • Mar 2006
                        • 8782
                        Will to help
                        Just my $0.02
                        Yes i totally agree 100% and in fairness i think a 3.5" pipe would be very easy compared to a 4" one.
                        It took me almost 2 days to get mine correct. This was tacked and not welded but now i can move mine in and out with just undoing the V-band at the turbo and at the bottom. The waste gate also has a seperate pipe that runs down and exit's at the gear box.
                        I had to cut my sub frame and re-weld it and also removed the lump of aluminum from the casting next to the starter on the gear box.
                        If you need help just ask, i suffered
                        Cheers James
                        Chef
                        • lind4hl
                          • Jul 2008
                          • 2465
                          Just my $0.02
                          Understandable.
                          BUT in the car that is spoken about ( s2 )
                          i´only see 1 way to go down, and not that different from a 3" dp.
                          so im almost 100% sure there wont be more backpressure with an 4" dp..
                          EDIT: Help is here also
                          • david
                            • Oct 2008
                            • 1268
                            2.5" = 19.63495"²
                            3" = 28.27433"²
                            3.5" = 38.48451"²
                            4" = 50.26548"²
                            mathematical genius, goodall
                            • david
                              • Oct 2008
                              • 1268
                              Understandable.
                              yeah lind4hl,what dp are you using at the moment.3" or 4"?
