Can't Get To Inside Bolt Of Downpipe
  • david
    • Oct 2008
    • 1268
    does anyone know's what spanner you need to to get to the inside bottom bolt of downpipe.just can't seem to reach it with a normal spanner.
    i remember a guy on here using a special bent spanner.
    any idea's welcome
    [SIGPIC][SIGPIC]/SIGPIC]92 3B pearl white=gone back home to Germany,probably in bits and pieces
    RS2 VOLCANO BLACK] soon to be broken to bits
  • adamw
    • Dec 2005
    • 348
    • Country: Shetland Islands
    Hi david, yeh you need a "special" bent spanner... Buy a cheep 15mm spanner, take it to your local garage and get them to bend the ring end to around 90 degree
    cheeRS adam
    RS2+
    • s2driveruk
      • 12696
      can get to it with a short 'laser' 15mm spanner....got mine off
      1992 3b S2 Coupe
      • david
        • Oct 2008
        • 1268
        imaging walking into your local garage asking them to bend your spanner,they'll might think your off ya rocker
        seriously....
        can't i just buy em
        • s2driveruk
          • 12696
          can get banana spanners from local motor factors, they should do the trick
          1992 3b S2 Coupe
          • nip
            • Apr 2006
            • 1786
            • Home: United Kingdom Current: Abu Dhabi
            Originally posted by david
            imaging walking into your local garage asking them to bend your spanner,they'll might thing your off ya rocker
            seriously....
            can't i just buy em
            Ebay
            • david
              • Oct 2008
              • 1268
              i'll be dreaming about bent spanner to night,i just can't believe i actually going out
              2morrow, to the shop looking for a bent spanner.
              • Phil Payne
                • Jul 2009
                • 328
                FACOM 57.13x15 Half-Moon Wrench
                FACOM, tout l'univers des outils à main et des équipements professionnels pour les métiers de l'industrie, de l'automobile et du bricolage.
                Page 149
                • david
                  • Oct 2008
                  • 1268
                  Page 149
                  cheers mate
                  • adamw
                    • Dec 2005
                    • 348
                    Seriously... Yes i am! you could just buy them if you want. When i had to take the downpipe off i ended up with the same problem, nowhere had the shape of spanner i needed so i spoke to a friend. Take it or leave it?! It only cost me £5
                    cheeRS adam
                    RS2+
                      You can get them from halfords
                      • Phil Payne
                        • Jul 2009
                        • 328
                        Nurdge. IIRC the Halfords "blister pack of 3" that I last saw didn't have a 15mm.
                          They sell a bigger pack that has it. I was going to buy one but Error404 is the DP bolt master
                          • Phil Payne
                            • Jul 2009
                            • 328
                            They also do a curved ratchet set but the walls are too thick to get on the nuts.
                            Maybe I should mention my favourite tool merchants (no commercial affiliation):
                            You want an extra-extra-long Beargrip 7mm Allen key (think top mounts) and you don't want the whole set? Mail order - 48 hours maximum.
                            • david
                              • Oct 2008
                              • 1268
                              them bolt's are 17mm in't?
