Hi,
after getting some issues with EGTs in 5/6 Gear at redline we started to explore the reason for this behaviour...
Its an compression dropped ABY with GT35R and 0.82 A/R...
we have no issuses to get the mixture rich enough.... so the fuel supply should not be the problem...
...we measured the exhaust backpressure after turbine and it was rising up to 450-500 mbar... that is a lot...
the mounted exhaust system is a 3" downpipe splitted Y like OEM ABY to 2 x 2,5" with 2 x 100 CPI cat and joined to single 3" behind the cats...
...after that - straight trough 3" with 2 mufflers - Coupe
...so after reading the forum I'm asking for any experiences with engines over 500/550 hp using one single 100 CPI catalytic converter without EGT issues...??
cause I'm planing to replace the 2 cat system with single 100cpi /76 cat to solve the EGT issue??
