S2 water manifold vs S4 intake?
  • max_s2
    • Mar 2006
    • 498
    • Country: Latvia
    Hi.
    Is it possible to use S2 water manifold with S4 stock-reversed-intake manifold? Stock S4 water manifold wont fit because of power stearing pump, so I'm thinking of stock ABY manifold vs S4 intake.
    Any ideas? Searched over the forums didnt find anything helpful about this.
  • Acidburn
    • 13459
    afaik with the aan inlet manifold you need the following:
    fuel rail
    manifold
    water rail
    is it possible to mod the bracket for the power steering pump, think thats what most people do, best person to ask is vincent if he still comes on as he's running a aan inlet on his.
    • martinjs
      • 3205
      You will have to modify an S2 water manifold for it to clear the AAN inlet.
      Here's the one i did.
      • max_s2
        • Mar 2006
        • 498
        • Country: Latvia
        Thanks, guys!
        martinjs looks nice, have you also used stock S4 fuel rail or modified somehow the stock one?
        • martinjs
          • 3205
          Stock S4 fuel rail is ok.
