easy (removable) exhaust noise suppression
  • s2driveruk
    • 12696
    Need some quick pointers on the art of hitting a noise test figure.
    Car was tested before a session at VAG day at Castle Coombe yesterday and 4500rpm, 45 degree angle and .5m away, was 103db - limit was 98db
    With a letterbox tailpipe, i couldn't bolt up a secondary silencer so any other ideas???
    to confirm the current setup, no cats, single smallish back box and single pipe to letterbox tail.
    Need to get it sorted ahead of ADI....I need to get it on track
    David
    1992 3b S2 Coupe
    i think you really need a removable 2nd box matey.
    dB is a logarithmic scale so 103dB is is half as loud again as 98dB so you need to do quite a bit to quieten that beast down
    • s2driveruk
      • 12696
      is it really that much louder than 98db?
      1992 3b S2 Coupe
        Yes it's actual a factor so 98db is 10 to the power of 9.8
        103 is 10 to power of 10.3
        In figures 98 db = 6309573445 and 103 db = 19952623150 !
        • s2driveruk
          • 12696
          any ideas what the effect of refitting just one of the cats would be....would it drag the noise back down enough and still be reasonably free flowing?
          1992 3b S2 Coupe
            Cats do make a difference, as above, get a centre box back in there, better than having the cat in the system at an important point earlier on! Not had mine tested yet but cat and decent back box should be OK...
            • quattro
              • Dec 2004
              • 768
              Are you talking OEM cat? that would be very restrictive, i would just go a head and get a nother box fitted.
              Probably the longet S2 project in history EVER!
              • s2driveruk
                • 12696
                i'm looking to keep the sound as is except for when tracking it to meet a noise limit. refitting one of the oem cats is a pain but is cheap (i.e. no cost) and should bring it down to around the limit I would hope. Trying not to spend money making the car quieter I might just get the letterbox shaped tail removed to a standard round tail so i can just bolt up an extra silencer. It a pain that Castle Combe is limited as much as it is. the car sounds great as it is, seems a shape to shut it up to get it out on track
                1992 3b S2 Coupe
                • turbodriver63
                  • Apr 2010
                  • 373
                  • Home: Ireland Current: United Kingdom
                  would someting like this be of any use?
                  http://www.demon-tweeks.co.uk/Perfor...sert/2050/5120
                  84 URQ 20VT
                  95 avant 80 TDI
                  87 CQ
                  • s2driveruk
                    • 12696
                    yeah thats the kind of thing, however it needs a long straight section which on the coupe is a problem with the box running across the back of the car
                    1992 3b S2 Coupe
                    • Fat Audi 80
                      • 10547
                      David, are you running twin bypass pipes? In which case you may need to bolt up BOTH Cats again to pass the noise regs. I see this the cheapest (no cost) way of doing it in the short term....
                      The cats will only rob 20 bhp or so won't they?
                      (Or fit the cats for the noise test then whip them off again in the pits! )
                      The Perfectionist
                        Cats aren't too bad on a stock car (mine was running stock cats when I got the RR runs of 294 and 297). It's more that a properly designed silencer is less restrictive than the emission friendly Audi cats.
                        David, I'd spend a little £ on a centre box that gets it to the correct noise and leave it, exhausts are a PITA to keep messing with. If you're really keen for noise then get a cutout valve under the rear seats
                        • s2driveruk
                          • 12696
                          thinking cats on for the session then just to get on with driving it then maybe a longer term solution for the future.
                          In terms of noise, at the moment i think its spot on, the sound is liberated from the car with no cats and its sounding more like i wanted it from day one BUT i cant be bothered with ongoing hassle to swap bits out whenever i want to venture out on track. It went round the ring and didnt trigger anything and the limit there was 98db which again it was well above.
                          Cheers for the input guys
                          1992 3b S2 Coupe
                            98dB drive-by is rather different to static test.
                            Suggest that you look into a full system including 3" DP and do it all properly. Prospeed were good VFM and did a nice job, will soon know if my setup passes, could do a lot worse than replicate that IMHO
                            • HPmuirt
                              S2Forum April Fool
                              • Apr 2005
                              • 3014
                              I like the idea of converting to a single cat system and then running a high flow cat on one side have a diverter valve into a short length of pipe which exits to atmosphere before it reaches the rear of the car.
                              You could either manually open the valve for track use using something like this or have it automatically open on full boost with something like this.
                              Cheers n
                              Si
                              Subtle mods here and there
                              2011 A5 3.0 TDi - Lava Grey
