screamer pipe
    The farty noise at part throttle is not very nice and is what generally makes people put a silencer on - that and the complaints from neighbours, wildlife and 'da fuzz'.
    • Audi-Porsche Avant RS2
      • Sep 2008
      • 1041
      • Country: Italy
      Hello, so N75 work also when for example from idle I accelerate with the car parked? Because I had hear mine work in this situation.
      Thanks!
      Alessio
      My life and my loves
      Audi S6 C4 ABT Avant
      Audi S2 Coupe ABY
      Audi S2 Avant
      Audi Cabriolet 2.0E
      • prj
        • Mar 2010
        • 6308
        Originally posted by Billman
        Oh yes, I am ordering one right now!!! Wait.... :-p
        Dude, let the "how does Motronic work" manual and read carefully please. I said the wastegate opens not the n75.
        And what do you think opens and closes the wastegate? N75. I recommend looking some at Paul's "Boost control essentials", it explains everything well.
        Also, it's not about "how does Motronic work", it's more about "I don't like people talking out of their ***" sort of thing.
        Actually Jamo said:
        Originally posted by Jamo
        It will open anytime you boost over the spring pressure.
        If it's a stock spring then 0.4 bar
        And you replied:
        Don't think so! It will open at 0.4 only if the n75 is disconnected. It will scream only when the ecu trust to controll boost.
        And this is incorrect, it is as Jamo said, it will open and thus the pipe will make some noises any time you go over 0.4 bar. The area where the noise is at it's maximum depends on throttle position, current boost and target boost.
        Have you ever considered the fact, that I might be speaking from experience?
        • A80Avant
          • Sep 2005
          • 10873
          • Country: Greece
          i probably know less than both of you, but if read correctly Dmitri, you are saying on one instance that N75 controls the opening and closing of the wastegate, and then below that you are saying that the spring and exhaust gasses are controlling the opening and the closing of the wastegate. Now something does not add up.
          If the N75 is disconnected, then has no effect over boost control AND the wastegate, then, yes it the spring is the only means of not allowing the gasses to open the wastegate. If the N75 is connected, then oscillates and allows more boost to be built by keeping the lower chamber of the wastegate pressurised. right?
          • Billman
            • 4129
            #20
            Man, i have read it a couple of years back when i was amazed about what Motronic can do.
            N75 or not the WG valve lets the gases pass. That why we are talking about when WG opens and not what regulates it. It could be a simple bleed valve the result would be the same. The WG would not open at spring pressure but more.
            pls do as all the favor and take your Motronic glasses off and think twice before you say your crap until puberty ends.
            Go Holset or Go RS4
            • [RPM]
              • Dec 2009
              • 229
              • Home: Portugal Current: Ireland
              #21
              its getting a bit out of hand lol
              i just wanted to know if anybody has one or how does it sound
              the real question is:
              if you run a screamer pipe can you have more power on the same diameter downpipe and exhaust system compared to a conventional wastegate pipe?
              I hope you can understand me
              • prj
                • Mar 2010
                • 6308
                Exactly like it is...
                Below spring pressure N75 has no effect, but as soon as you go over spring pressure it will start to bleed little amounts of air, whether you have reached target boost or not.
                Doesn't matter which solenoid or engine management system you use. If it didn't do it, you would overshoot boost very hard. The closer you approach to target boost, the more it bleeds. With stock ECU management part-throttle boost target is a lot lower than WOT (to limit stress on the turbo), so just driving around at part throttle it will make lots of noise.
                Correct, but due to the oscillation it makes a bit of noise all the time.
                For the third time, you said that it will open at spring pressure only if N75 is disconnected, which is not true, as even with N75 connected it will bleed small amounts before it reaches target boost. Not noticeable in spool, but it is possible to hear it with a screamer pipe.
                Talking out of your ***, then resorting to personal insults once you have been proven wrong surely must be very mature. :corey:
                Sounds annoying. But it's a matter of preference, try it out and see (hear) for yourself. To me it sounds even more annoying than a BOV.
                if you run a screamer pipe you can you more power on the same diameter downpipe and exhaust system compared to a conventional wastegate pipe?
                No.
                • [RPM]
                  • Dec 2009
                  • 229
                  #23
                  why not?
                  the exhaust will be flowing less
                  • prj
                    • Mar 2010
                    • 6308
                    why not?
                    I honestly doubt there will be noticeable difference.
                    How much HP does your car have?
                    • [RPM]
                      • Dec 2009
                      • 229
                      #25
                      it has a mrc chip should be around 280 ( back in the day)
                      but that's not the point
                      I'm just trying to know the facts
                      • Bram
                        • Aug 2006
                        • 2582
                        If the exhaust system becomes a restriction in terms of flow, then yes a screamer pipe can bring extra performance, as not all exhaust gasses need to be pushed through the full exhaust system. However I don't think that your existing setup will benefit it. You most probably need a remap to take advantage of it.
                        • Billman
                          • 4129
                          #27
                          You are right i apollogize! You are not personal when saying talking out your ***!
                          But tell me something master: Are you familiar with the term WG Creep?
                          Go Holset or Go RS4
                            #28
                            Frig sake chaps - put a lid on it... can we keep this thread on topic and NON personal. Nobody has anything to prove here.
                            • Billman
                              • 4129
                              #29
                              You are right, i stop here.
                              Go Holset or Go RS4
                              • [RPM]
                                • Dec 2009
                                • 229
                                #30
                                thank you Bram
                                that is what I though regarding the extra performance
                                on my setup of course I wont fell anything
                                when I will replace the downpipe and exhaust i will give it a go
                                I don't mind the noise
