In the process of constructing my manifold and i have a question regarding the hole between the 2 plenum's.
What size do you think i should make the hole?
Im currently thinking 450mm x 6mm, ill show you my working out....
2.5" boost pipe (1.6mm wall)
(2.5x2.54)x10=63.5mm
63.5-(1.6x2)=60.3mm (boost pipe I/D)
Do for the surface area of the boost pipe........
3.14x30.15x30.15= 2854.33mm2
and the hole for the 2nd plenum
2854/450=6.34mm
Makes sence?
2854/450=6.34mm
Makes sence?
, Wall thickness not under 3mm.
