Exhaust wrap - a good idea?
  • Mark Halligan
    • 2001
    Is it a good idea to wrap cast iron exhaust manifolds, or will keeping the heat in render the casting more likely to cracking. I am sure that I heard/read somewhere before that it could cause a cast iron manifold to overheat and damage it??
    Cheers,
    Mark.
    Mark - Modded
  • Habib
    • 316
    • Home: United Kingdom Current: Italy
    Cheers,
    Mark.
    I would wrap the ss downpipe instead of the cast manifold it could overheat and crack
    • Habib
      • 316
      Im thinking of getting a heat jacket for the exhaust side of the turbo. Would this be a good idea?
      • sorens2
        • 241
        • Country: Denmark
        Hi
        I´m having mine ceramic coated in USA.
        That really works on our racecars.
        Søren S2
        Audi RS4 LO550
        BTG 8:08
        www.fredslunds.dk
        • Graham
          • 1622
          Originally posted by SøernS2
          Hi
          Søren S2
          We use ceramic coating 2 pack compound from belzona molecular, i coated over the small cracks on the manifold, i will check to see if the fix has worked, but we use it to protect bearing housings (water cooled)that the orange hot metal passes over. Seems to work well on them (they are constantly running 2" under a 1200 degrees c slab of steel). Got a pack in the garage and might try it on the downpipe, cannot see why it wouldnt work.
          • timucin
            • Nov 2003
            • 869
            • Country: Turkey
            i have;
            wrapped all pipes
            painted with heat isolator spray
            installed turbo jacket
            +have lots of heat barriers,between exhaust and engine ,exhaust and intake pipes,exhaust and body
            using würth products, which is only avaible product here
            wraps and turbo bag from dei
            Quattro
            • sorens2
              • 241
              • Country: Denmark
              That will work, timucin.
              Søren S2
              Audi RS4 LO550
              BTG 8:08
              www.fredslunds.dk
              • Mark Halligan
                • 2001
                Too late/broke now to get it ceramic coated, I am still thinking about the wrapping it though. I repainted it tonight and cured it in the oven, while the girlfriend was out :mischeif:
                Mark - Modded
                • Graham
                  • 1622
                  This is the product which we use for ceramic coating. it produces a glossy finish and this one is blue, we have red, and grey also (even though there is not alot of difference in colour, its more like grey with a touch of red/blue)
                  Graham
                  • charlie
                    • 447
                    This might help. Its by Dhalback racing.
                    RS2 MTM
                    • Sweeper
                      • 1317
                      • Country: Latvia
                      Question: Where can I buy such heat wrap/tape ?
                      Vadim.
                      • Graham
                        • 1622
                        It Just looks like fire blanket material, probably fibre glass one side and shiny on the other to reflect the heat back in.
                        Graham
                        • Stick Insect
                          • Dec 2003
                          • 2338
                          [QUOTE=Mark Halligan] cured it in the oven, while the girlfriend was out /QUOTE]
                          A friend heated up the head of his Lotus Elan in the oven to install new valve guides. The oven stank of oil for weeks afterwards!
                          David
                          • Beetie
                            • Oct 2003
                            • 1517
                            [QUOTE=Stick Insect]
                            David
                            Mark has previously baked things in the oven while his missus is out, cant remember what tho'!
                            • audiman
                              • 4827
                              LOL @Mark. Next time i see her.......
                              I thought of doing this with mine too. BUT.... the only problem being is that should the car develop an oil leak and it gets on that wrapping it catches on fire very easily.
                              Almost BTDT.
                              The choice is yours, it shouldnt leak oil, but then **** can happen.
                              Tom C - www.rcmr.co.uk
                              Audi UR Quattro
                              Audi 100 C3 2.0 5 cyl 115ps
                              Audi B5 RS4 645ps 911nm
