Block breather diameter
  • Rusty
    • 18953
    Can someone please measure the block breather pipe diameter for me - the metal bit on the block
    Ta
  • JP
    • 1858
    I've used 19mm hose to go over the spout for mine after the juction box. The bit before it I'm sure I used 28mm.
    UrS6 Stroker + HTA3586 =
    • Rusty
      • 18953
      Yeah, I'm after the measurement off the larger bit, the union pipeexit is indeed 19mm, albeit a curved pipe.
      If someone can get a picture of the crank outlet as I've heard a few diameters (28/30/32) and want to get it spot on. It's a bit of a PITA to take all the stuff off my car to measure it, hence asking the question... Once that's done I can sort out a thread with all the sizes clearly stated for the breather system.
      • JP
        • 1858
        Can't believe you just got me up to go and measure. But anyway the OD of the outlet measures 29.75mm and the hose I used on mine was 28mm ID silicone.
        • Rusty
          • 18953
          Cheers JP Have a cup of tea to recover
          • JP
            • 1858
            I know all this hard work just not used to it. I mean i had to put the TV remote down!
            • Rusty
              • 18953
              I'm suprised you'd managed to lift it up in the first place...
              Originally posted by Levi Roots
              Rrespec due
