Howdy folks,
I'm building a 3.5" (89mm) turbo back exhaust for my s2 coupe.
It'll have a flexi secton at the front between the DP and the cat. The cat will be 200 cpi metallic and will be removable to be replaced with a straight through pipe.
2 x lambda bungs and an EGT bung.
2 x silencers as per the stock item, one in the middle and one at the back with twin tailpipes.
Stock hanging points will be used as much as possible.
The pipe will be oval at the front where it comes under the subframe and it will also be oval at the back where it goes over the axle.
It'd be easy enough to put a few v bands into it to make it shipable so my question is would anybody be interested in having one? I'm not after a committment to purchase but just wonder if anybody out there doesn't have a stainless system at this stage and is planning to buy + planning for bigger power.
Exhaust will not be loud, compared to many big bore straight through items.
Lead time could be 3-4 months, I have the DP almost completed.
Regarding the price, somewhere between €600-€1000, I don't know yet.
for Rs2.
