hey guys i have a question im building the down pipe for my holset hx40, and was running into some confusion with my brother, im trying to route the wastegate into the exhaust downpipe, and my brother is saying to leave the waste gate pipe seperate running open under the car, what is the benefits of each, and will the open wastegate pipe give me more chatter? thanks
wastegate outlet??
Really it depends on what the car will be used for.
But like Billman says a separate pipe is better because it doesn't inhibit flow of the exhaust as much as the wastegate gasses have there own exit pipe. However the extra noise, and there will be plenty of that at full chat may be a problem on some tracks and may also get irritating when driving.
I have heard of motorbike silencers being used on separate wastegate pipes to silence them a bit..91 S2 coupé - RIP
98 S8 - Luxury bargeComment
Wastegate diverts exhaust gas around the turbo, diverter valve recirculates air from the pressure side to the non pressure side of the turbo.
Thread from a few months ago, some opinions and arguments;
Sold ABY-stockComment
Are you sure you are not mixing wastegate with blowoff/bypass?Comment
read up on this post and looks like something i can handle im not easily annoyed by the loud sound, however best way is to give it a try, cause you can always add a restrictor onto it, and if its true that it frees up airflow, and adds hp thats just that much betterWastegate diverts exhaust gas around the turbo, diverter valve recirculates air from the pressure side to the non pressure side of the turbo.
http://www.s2forum.com/forum/showthr...light=screamer
