Wiring loom for Reverse Mount IM
You have to extend the throttle body and the ISV. Also check the MAT plug will reachLeave a comment:
I need the car for a track day event happing soon , so have decided to extend the wires for now. But I beleive lots of people will benefit from a plug in solution
I'm not sure, maybe it will just reach as its not too far from its original location.
Edit; just been and had a look, it should reach no probs
Nice one Paul!
I'm doing the 3B so will need to extend and solder the IAT sensor anyway but a broken O2 sensor is a source of a 2 pin male with decent wire on it already.
We'll need to do the ISV too I guess, unless it will reach..Leave a comment:
Good effort Paul, I spent an hour or two on the Tyco website last night too
I will call Taylors tomorrow to try and get prices for the bits. I assume that they are Bosch Numbers?Leave a comment:
Found it in the old Bosch paper catalog
6-pin MALE = 2 227 000 104 - there is a question whether supplied pins are perfect for this but lets see
6-pin FEMALE = 1 287 013 004
2-pin MALE = 1 287 013 002
2-pin FEMALE = 9 122 067 011
All above parts are supposedly kits that include pins and rubber boot. I'll try a couple of Bosch suppliers for prices - anyone else is welcome to try their local sources as well of course.Leave a comment:
I have spent best part of an hour scouring the web for any type of 6-pin MALE JPT connector that is compatible with AMP/Tyco or Bosch.... Need to dig up the old Bosch catalog I found a while back.Leave a comment:
Great, thnx Paul,
If you are able to source the plugs I will definitely order a TPS extension and an Inlet Temp extension
I remember now... The 6pin male is odd as I only found bulkhead or pcb style connectors before now - like on the MAF or the TPS. Will keep looking.Leave a comment:
Part no for the femal MAF connector
"MAF uses 6-pin JPT connector, VAG part 022906233A for housing + 022906102B boot"Leave a comment:
