AAN serious Maf trouble..
When the car was finished we estimated 4,54 bar for fuel preasure was the right amount, and thats the way its been all the time and working well (nice afr numbers),
I did disconnect the 02, even swapped it with a brand new oem one i had lying around. No difference..
95 RS2
97' S6 2.2T 460hp setup
00 GSXR 750
Protected movement - with quattro.Comment
Hm, is the connection to the FPR alright?
You don't have an issue with a leaky injector?
Car running rich on idle:
a) O2 sensor stuck on lean
b) Incorrect fuel pressure
c) Incorrect MAF signal/bad MAF
d) Injector(s) stuck
I don't think there can be anything else if it worked properly before.
Any kind of holes or leaks in the intake would make it go lean on idle, not rich, because it would suck in extra air that does not go through the MAF.
Misfire will always show lean as well (O2 not used).Comment
a) CheckedHm, is the connection to the FPR alright?
b) same as before, so hopefully that shouldn't be the problem
c) 3 different mafs giv the same result (tested fine on other aan cars)
d) Only thing i've tried is to disconnect on at a time when the idling and there where difference. But if one or two isn't closing propperly that might cause some serious problem?
Any easy way to check the injectors? just taking the whole fuelrail with injectors out and se how the spray? with pos disconnected..95 RS2
00 GSXR 750
The best way is on a special ultrasound washing stand for injectors.
How are you adjusting fuel pressure? If it's some cheap chinese adjustable FPR - I had very much trouble with them before.
The MAF signal - maybe not the MAF is bad, but the connector?
Try measuring the voltage from the MAF at different stages.Comment
got a drop-in adjustable fpr from 034 that i hope is of good quality?The best way is on a special ultrasound washing stand for injectors.
Measuring the maf, well.. now i'm on thin ice....
The wires coming from the car to the maf, can i measure each of those (with maf disconnected) and what will the different coloured wire show? (if possible)
and how to measure the maf would be interesting to know as i kinda hate electrics...
hehe95 RS2
00 GSXR 750
I had something like this before.If i pushed the throttle smooth i could rew it to 3000 rmp.If i got on boost side i got instant limp mode.Seems to me like a masive leak.
My problem was a 3 cm crack on the turbo to intercooler pipe.
I know this seems to simpple,but i had another one:
Map sensor error.After cecking n75,thinking of removing the wastegate i found the hose going from intake manifold to ecu NOT conected to moisture trap.
So..Get to a boost test of your sistem.Comment
Btw, if there is a heavy leak somewhere in one of the vacuum hoses, that connect to the FPR, you can flood the engine as well, because fuel pressure will go up at idle.
Check all these things.Comment
This thread and chat is very interesting. Please, go on...
