K24R Oil Filler Cap Breather
  • Rusty
    • 18953
    I'm designing a new filler cap to enable it to be used as a breather instead. The reason for this is that the head breather is in a poor location and serves to drain oil under hard accleration, rather than vent the head!
    I am looking at the option of using an M20 tapped hole, to enable either a -10 or -
    12 AN adaptor and then union or barb, for proper oil hose. This adds about £20-30 to the cost for an adaptor and union, depending on spec.
    For a more basic product, I could to re-use the PCV 90 deg rubber bend and a pipe union or solid pipe, to enable 19mm pipe to be used, of course, a silicon hose can also be used, should you want to bling it up a bit. The issue here is with having a feature to provide sufficient grip to enable easy access, due to machining access. It might be a case of using the hose clip for the rare occasion the oil gets refilled
    The product retains the standard method of twist fitting and sealing and would be anodised aluminium.
    pure guesswork at price, IIR £50-60 but solves a problem with these cars and is totally removable.
    Anyone interested?
  • LHD_Kid
    • May 2006
    • 3697
    Originally posted by Rusty
    Anyone interested?
    Yep.... assuming 3B operation (and some aftersales advice with sorting my breather with one of your catch tanks...! (when funds allow....)
    Chris
    • Rusty
      • 18953
      Revised this now. It uses an NPT thread, that enables any off the shelf NPT to XX adaptor, so AN, hose barb... whatever you want
      • Sonic
        • Jul 2006
        • 5514
        A breather through the filler cap, with a tapped hole for an AN adapter? Interesting idea Andy
        S2Forum.com Administrator
        • Rusty
          • 18953
          Just enquiring about NPT fittings from Earl's. The idea would be that you can fit any NPT 3/4" fitting, either a hose barb or AN / JIC fitting
          • Sonic
            • Jul 2006
            • 5514
            Yep, something like this - http://www.speedflowshop.co.uk/-12-j...6-12-809-p.asp
            • Rusty
              • 18953
              This
              or this
              The 90 is required for clearance on the bonnet.
              Nearly got the design sorted, will require destroying a new filler cap to get the seal and locking mechanism. Going to get some tomorrow and reverse engineer them.
              • merlin's S4
                • Jan 2005
                • 1539
                Good idea this.
                Should also allow easy fitting of an unmodified 7A cover where required as the 7A cover has no breather outlet.
                • Rusty
                  • 18953
                  Problem is that 3/4 NPT fitting is a bit large. I need 1/2" NPT to 16mm (5/8") or 19mm (3/4"), like these -
                  http://www.jegs.com/i/Turbonetics/880/30245/10002/-1
                  http://www.jegs.com/i/Gardner-Westco...J9003/10002/-1
                  I need to speak to Earl's, looks like they do a 5/8 hose to 1/2" NPT fitting. Ideal
                  • Sonic
                    • Jul 2006
                    • 5514
                    I was thinking this + this or similar to make the oil cap a bit neater with just a nipple poking out the top.
                    • terrybullwon
                      • Mar 2006
                      • 8782
                      Yes that is the correct way to do it.
                      Chef
                      • Rusty
                        • 18953
                        Beauty is, you can do it however you want to
                        It'll be a 1/2" NPT thread, 3/4" is too large for the retaining mechaism to be made around. There are -10 and -12 adaptors available in that size
                        Will finish up the design and get a prototype made somewhere.
                        • andy10v
                          • 5996
                          That is what I am working on just now, except with house plumbing bits just now
                          Locking mechanism is right in the way though.
                          Sold ABY-stock
                          • s2driveruk
                            • 12696
                            so blank off the stock rear outlet then run this instead back into the PCV Andy?
                            1992 3b S2 Coupe
                            • Rusty
                              • 18953
                              Yes, no more oil running out the stock breather. Will fit most VAGs too
