TTRS/RS3 turbo
  • Jon441cc
    • Dec 2005
    • 2061
    TTRS/RS3 turbo
    This is the turbocharger used in the new TTRS and RS3 5 cylinder engine, as you can see from the photo it has a combined manifold and turbine housing. Am I right in thinking this aids in reducing turbo lag ?
    Has anyone got any technical info on the new 2.5ltr engine and what boost pressure it operates at ?
    [IMG][/IMG]
    that thing looks really ****ing expensive!
    • Jon441cc
      • Dec 2005
      • 2061
      Interesting reading
      An all-new engine designed by AUDI AGs high performance subsidiary quattro GmbH, harking back to the original turbocharged five cylinder Audi engines in the "Ur-" Audi Quattro of the 1980s. A world first for a petrol engine, its cylinder block is constructed from compacted vermicular graphite cast iron (GJV/CGI) - first used in Audis large displacement, high performance Turbocharged Direct Injection (TDI) diesel engines.
      identification
      parts code prefix/variant: 07K.3; ID code: CEPA
      engine displacement & engine configuration
      2,480 cubic centimetres (151.3 cu in) inline five engine (R5/I5); bore x stroke: 82.5 by 92.8 millimetres (3.25 in × 3.65 in), stroke ratio: 0.89:1 - undersquare/long-stroke, 496.1 cc per cylinder; 88 mm (3.46 in) cylinder spacing, 144 degree firing interval, firing order: 1-2-4-5-3, compression ratio: 10.0:1
      cylinder block & crankcase
      GJV-450 compacted vermicular graphite cast iron (GJV/CGI); six main bearings, two-part cast aluminium alloy horizontal-baffled oil sump, simplex roller chain-driven oil pump, die-forged steel crankshaft, forged steel connecting rods, cast aluminium alloy pistons (weight, each, including rings and gudgeon pin: 492 grams (17.4 oz))
      cylinder head & valvetrain
      cast high hot-strength aluminium alloy, modified inlet duct geometry for high tumble values providing superior knock resistance, four valves per cylinder (exhaust valves sodium filled for increased cooling), 20 valves total, low-friction roller finger cam followers with automatic hydraulic valve clearance compensation, simplex roller chain-driven (relay method) light-weight double overhead camshafts (DOHC), variable valve timing with continuous adjusting intake and exhaust camshaft timing of up to 42 degrees from the crankshaft, two-stage 'valvelift' variable lift control for inlet valves, siamesed inlet ports, Audi "RS" 'red' plastic cam cover
      aspiration
      hot-film air mass meter incorporated into air filter housing, cast alloy throttle body with electronically controlled 'drive by wire' throttle butterfly valve, two piece intake manifold with charge movement flaps adjusted by a continuous-action pilot motor, water cooled turbocharger incorporated in exhaust manifold with 64 mm (2.5 in) diameter outlet, generating up to 1.2 bars (17.4 psi) boost, separated central lower front-mounted intercooler (FMIC)
      fuel system
      fully demand-controlled and returnless: fuel tank-mounted low pressure fuel lift pump; Fuel Stratified Injection (FSI): single-piston high-pressure injection pump supplying up to 120 bars (1,740 psi) fuel pressure in the stainless steel common rail fuel rail, five combustion chamber sited direct injection sequential solenoid-controlled fuel injectors, air-guided combustion process, multi-pulse injection with homogeneous mixing, stratified lean-burn operation with excess air at part load, ultra-low sulfur unleaded petrol (ULSP)
      ignition system & engine management
      Beru longlife spark plugs centrally positioned in combustion chamber, mapped direct ignition with five individual direct-acting single spark coils; Bosch Motronic MED electronic engine control unit (ECU), cylinder-selective knock control via two knock sensors, permanent lambda control
      exhaust system
      secondary air injection pump for direct injection into exhaust ports to assist cold start operation, cast iron exhaust manifold (with integrated turbocharger), two primary and two main high-flow sports catalytic converters, two heated oxygen sensors monitoring pre- and post-catalyst exhaust gasses, vacuum-operated map-controlled flap-valves mounted in rear exhaust silencer tail pipes
      dimensions
      length: 494 millimetres (19.4 in), mass: 183 kilograms (403 lb)
      DIN-rated motive power & torque output
      250 kilowatts (340 PS; 335 bhp) @ 5,400-6,500 rpm (specific power of 100.8 kW (137.0 PS; 135.2 bhp) per litre); 450 newton metres (332 ft·lbf) @ 1,600-5,300 rpm; redline: 6,800 rpm
      300 kilowatts (408 PS; 402 bhp) @ 5,400-6,500 rpm; 480 newton metres (354 ft·lbf) @ 1,600-5,300 rpm; redline: 8,000 rpm
      application
      Audi quattro concept (2010), Audi RS3, Audi TT RS (07/09->)
      • s2driveruk
        • 12696
        cant even begin to imagine one of those as a 2nd hand bargain...when that goes wrong..CH CHING Those FSI injectors are like the pump-dusse unit injectors. Believe me, painful experience of getting those sorted on my a6 avant last month £720 for 4 to be tested and refurbished.
        1992 3b S2 Coupe
          Interal wastegate and actuator urggggggggggggggh, that's going to friggin cost if it goes wrong!
          • saltinot
            • May 2004
            • 1946
            This has just changed my mind about wanting an RS3
            • Rocco
              • Aug 2007
              • 6393
              • Country: Spain
              turbo seems to be welded to the exhaust manifold??
              • quattro
                • Dec 2004
                • 768
                id say they are cast marking, it looks one pc
                Probably the longet S2 project in history EVER!
                • Billman
                  • 4129
                  it is one piece. Opel did it first if I am right on the C20LET engines on calibra etc.
                  Go Holset or Go RS4
                  • mcandmar
                    • Apr 2004
                    • 5118
                    Why does that seem like a really bad idea. Has Audi every made a 5cyl manifold that didnt crack?
                    91CQ20v - Gone to a new home
                    93UR-S4 - The Magic Carpet
                    94S2Bus - The Emerald Express
                    • repo
                      • Dec 2004
                      • 893
                      Yea, people, looking for 15 years old TTrs need to be aware of the issue of cracked manifolds.
                      • Sir Buff
                        • May 2004
                        • 127
                        • Current: Switzerland
                        The compressor wheel is interesting. It's better and lighter than the RS2 wheel ;-)
                        2480DXB i think.
                        http://www.audi90.ch
                        • fish
                          • Aug 2007
                          • 2335
                          • Home: United Kingdom Current: Sweden
                          How is the manifold/turbo held o the head? there´s no bolt holes...
                          Audi 80 Competition -94 Daily driver
                          www.garaget.org/fish for more pic´s of my cars
                            A combination of scrambled agg and mashed potato. once dried on, this is some of the strongest adhesive known to man
                            • Fat Audi 80
                              • 10547
                              and porridge of course...
                              The Perfectionist
