AAN Downpipe?
  • byd1380
    • Aug 2009
    • 269
    AAN Downpipe?
    I have just bought a S6, it came mapped (S2Central) and a 3" stainless exhaust with the cats removed.
    It has the original downpipe fitted and still splits into 2 sections (45mm each) as per original, then joins back up to the new 3" system, I just don't think it makes sense.
    I was going to fabricate my own downpipe from just below where the wastegate pipe enters it, I measured it at 65mm, so was going to use 2.5" stainless, would this be restrictive or better than current setup. I will be leaving the car in current tune for a while, then just do a tuning package in one go, FMIC, 3" downpipe, Turbo etc.
    Ivan
  • prj
    • Mar 2010
    • 6308
    Stock UrS6 exhaust is easily good enough beyond RS2 levels of power...
    If you are making a DP anyway, you should go 2.75"... or 3"...
    Stock DP is 2.5" afaik with two 2.25" split pipes until the end.
    If you look at cross section alone, then 2x2.25" gives you more cross section than 3".
    You would definitely benefit from a larger DP, but the exhaust on a UrS6 is very good as is.
    If weight is not much of an issue, and you want the car not to be loud, then I'd just remove the bodge you have now and find a decatted stock exhaust.
    • byd1380
      • Aug 2009
      • 269
      Yeah, might be a better option, I just dont like the current design of splitting into 2 and then joining again, a few hours with the welder would hopefully sort it out. I would then replace the whole downpipe with a bigger one once I change the turbo etc.
      Cheers.
      • byd1380
        • Aug 2009
        • 269
        AAN downpipe
        Well, was off a day from work, so decided to make a new 2.5" downpipe, it's only a temporary measure, going to replace it with a 3" at some point, prob when I change the turbo etc. The car had a standard downpipe but had the cats removed. I have attached a few pics. Just took a few hours with the welder, I used a old 3" flange from a decat for a 1.8T I had.
        Before
        After
        The rest of the systrem is a 3", the exhaust note is alot deeper now, a bit loud but will do.
        Ivan
        • diesel des
          • 3896
          Braap
            @Ivan - maybe you can knock up a nice 70mm dpipe for me and decatted front section someday you have nothing to do !
            • byd1380
              • Aug 2009
              • 269
              No probs paul, hopefulyy once I get my MG sold i'll be buying a full turbo/mainfold/DP set up, so you could have the one from my car, i'm sure it wouldn't take much to fit it.
              Any luck with your ECU? Was it the Map sensor messing about?
              Ivan
                investigation underway... will let you know ASAP
                • OrMar
                  • May 2007
                  • 132
                  • Country: Croatia
                  Did you test that ? Did it affect EGT ? Any power loss ?
                  I'm looking forward to finally employ my RS2 turbo/injectors/EM, but I like quietness of stock (decat though) URS6 exhaust so much.
                  Thanks,
                  Mario
                  • RS2
                    • May 2005
                    • 400
                    No flex joint?
                    MG
                    • byd1380
                      • Aug 2009
                      • 269
                      No flexi, wasn't one on the original downpipe, doesn't seem to make any difference.
                      Ivan
