exhaust manifold cast would it weld to stainless?
  • K7ERG
    • 1711
    Wondering if cast and stainless can be welded together? Calling all welders
    Audi A6 AEL 5cyl Quattro breaking.
    Audi A5 3.0tdi Quattro Stage 2
    07947385043
    In a word, no. What is it you're trying to do?
      It's possible but is a very specialist job, what is it your trying to do? if it's aftermarket wastegate use a flange welded to the vband for example
      • K7ERG
        • 1711
        the downpipe is V band but changing the turbo so need to to connect the downpipe to exhaust housing using v band.
        Will try get my hands on a AEL downpipe and see if i can do anything with that.
        07947385043
          What turbo? if it's garrett buy the vband adapter.
          It can be done Comp turbo do it to their housings but I think it's looks a nasty job
          • K7ERG
            • 1711
            Its a K24
            07947385043
              What size is the vband? as a 3" one couldn't be welded onto a k24 it's too small.
              Better off making an adapter using the K24 flange, cone SS and then Vband connector.
              • K7ERG
                • 1711
                Thats what i done on my downpipe for the AAN. I used the K24 flange and welded a ss cone to take the 3" downpipe.
                My problem is i dont have a K24 downpipe to chop and i would like to keep the 3" v band downpipe.
                07947385043
                  You can buy the flanges, s2spike, AndyP can point you in the right direction.
                  • Lupo911
                    • Apr 2005
                    • 312
                    yes its possible. What Kind of Cast Material is it? If its like high Nickel Stuff,D5S or 1.4848, you can weld Stainless Steel with Inconell wire. (Tig) Works very good.
                    • K7ERG
                      • 1711
                      what ever the k24 housing is made of???
                      07947385043
                        I stand corrected - didn't know this was possible
                        • Thuppu
                          • 4115
                          Do a V-band adapter.
                          • Lupo911
                            • Apr 2005
                            • 312
                            yes, then it should be easy, with Inconell Wire and Tig.
                            Its important to clean up the Cast Part, it need to be bare Metall. Heat both Parts up and weld it together. Make sure you will cool it down very very slow!!
                            • [RPM]
                              • Dec 2009
                              • 229
                              • Home: Portugal Current: Ireland
                              after welded heat up the 2 parts again until red
                              to cool down slow fill half a bucket with sand place the welded part and cover with sand leave it for a good wile
